SOURCE: LS430 check VSC light on after check engine light on
My car (06 GS430) began giving me more frequent "Check VSC" warnings. (Code P0455 in my case. Really glad I bought that OBDII tool--resetting the codes is a snap!)
I knew that a loose gas cap could cause this, so normally I just give it a twist and it tightens. Now I found that no matter how many "clicks" I tightened the gas cap, it would not cinch down snug. The lightest turn the opposite way would open it.
I was all set to head over to CarQuest for a replacement filler cap. But I thought I'd inspect mine first just to see why it stopped holding. Upon inspection, I saw that what holds the cap in place is compression of the rubber O-ring at the back of the cap, which compresses against the filler neck. That apparently was no longer happening.
I carefully removed the O-ring from the cap--using screwdrivers to lift it over the edge of the groove it sits in. Like removing a bike tire from the rim--work your way around. Then I cut a strip of electrical tape about 10" long, and 1/4" wide. I wound this into the curved groove where the O-ring normally sits, just to build up a little thickness. Put the O-ring back in place. Done.
Now the cap tightens like it's supposed to, and thus far, it has stopped the VSC error codes. Don't know if it will fix your issue or not, Good luck.
SOURCE: check engine with vsc & vsc off light came on
Autozone will check your engine codes for free.
SOURCE: 2007 lexus rx350 ,vsc light on and check engine light is flashing
First check and make sure your gas cap is tight, if this does not resolve the problem read below.
A vacuum hose has become disconnected, more than likely due to having your air filter replaced. The VSC and Check engine light typically don't come on until after 150-200 miles after the vacuum hose was pulled out.
The fix: on the right-hand-side of the engine compartment behind the big plastic housing that holds the air filter you will find a black rubber hose that is not connected to anything. Squeeze the finger clamp on the hose and slide the hose back onto the half inch nipple on the back of the air filter's plastic housing.
In order for the VSC and Check engine light to be turned off, you will need to open the fuse box, right-side of the engine compartment, and pull the 20 amp EFI fuse for 10 seconds. This will reset the system. The fuse location is marked on the lid of the fuse box, also I believe the EFI fuse is the only 20 amp fuse
. This will help. Thanks, please keep updated. please do rate
the solution positively .thank you for using fixya
SOURCE: VSC, Trac Off and Check Engine
disconect the batery ground for 30 minutes and it will reset the computer
SOURCE: trac off, trac vsc and check engine engine lights
Battery was diconnected for 1 minute and then reconnected. All lights are off.
