Question about Black & Decker Hedge Hog Cordless Hedge Trimmer
Have black & decker hedge hog wants to bind up all the time seems like blade are not tight enough together
4 Suggested Answers
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
  • 18 Answers
SOURCE: Black & Decker Hedge Hog 24-Inch Hedge
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Posted on Apr 29, 2010
  • 333 Answers
SOURCE: what thickness of a branch will the black and
probably what ever will fit between the teeth
Posted on May 16, 2010
My Mod. 2400, type One is dull--7yrs. old. How do I sharpen it? Thank You
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results.
Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Sep 13, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
My electric hedge trimmer blades do not move when it is turned on. Suggestions? hs2400 date code 20021249
Check that the bolts or screws holding the two blades together aren't too tight preventing the blades sliding. Lubricate the blades also with WD40.
Jul 14, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
My 22inch Hedge Hog trimmer (model cht500) 14.4v blades are moving very slowly. Purchased another charger but that did not help the situation. Any thoughts -battery need replacing?
possably the cells in the batt r warn out, take the battery appart nd charge nd c if they r holding charge, if they are you can buy them from a shop on ebay which is really cheap, there probably 1.2 volts, 1400 mha which is tiny. ive got 6800 mha batts in my hedge hog
Mar 12, 2011 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Need diagram of blade assembly for Hedge Hog HS 2400 Type 1. Need to know how the spacers and eccentric are laid out between the blades.
try hulufile.com its a good source for pdf manuals on 2 stroke machines. i hope you find this useful as i use them alot ..
Nov 23, 2010 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Think we need new blades for our cordless hedge trimmer. Where can I get them??/
Try the place where you made your purchase. If they don't have them in stock...Maybe they can order the correct blades for you. If they are not a Black and Decker dealer. Try on Line at their website.
Oct 06, 2010 | Black & Decker Hedge Hog Cordless Hedge...
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Do I ever need to sharpen? If I do, how?
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
  • Work table
Tips & Warnings
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Oct 28, 2008 | Black & Decker Hedge Trimmer
Black & Decker Hedge Hog  Cordless Hedge Trimmer  Logo
103 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
