Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer is draining into bottom drawer and bottom drawer is draining into top drawer
Hi, Make sure that the drain hoses are looped at least as high as the top washing part. With no loop the water is free to pump from one drawer to the other. I simply tied the hoses up under the sink with twist ties. That was over 2 years ago and haven't had the problem since. Good luck!
Posted on Jul 19, 2009
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Jan 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a F&P Model DD602I. I had a repairman out to change out hoses that were bad and now I have this problem: When I just run the bottom unit, it works fine, but a bunch of water ends up in the top...
Try to isolate the drain hose of the top drawer by disconnecting from the U hose. Run the bottom drawer.
Similarly isolate bottom drawer and then run top drawer.
See if problem is linked to back flow from drain.
I am assuming by now you may have already solved the problem.
Aug 15, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
After top drawer is run, bottom drawer has
check the check valve on bottom drawer. unplug hose drain hose off drawer underneath. a small ruber check valve can be clogged. if its good replace it
Feb 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
270 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
