We have a model FRS26ZNHB1.. For a while we had to tap on the cold control in the freezer. All we get is a ticking sound when we try to turn on. A techician came out 3 weeks ago and since it was working then, he didn't recommend a new motor. now it won.t turn on and obviously the fridge is warm now?
Is the compressor running? The noise you hear could be the clixon on turning on and off. If that is the case, it is sort of like a circuit breaker that turns off the juice to the motor when it is drawing too much current (when it is frozen). If not running and hot to the touch and you keep hearing the click go on and off then the compressor on unit has gone to compressor heaven. U might also check to see if the start relay/capacitor is any good - if defective it will prevent motor from starting and cooling the unit.
