Question about HP Computers & Internet
How do I type extended characters on my laptop? On a desktop I get the extended characters using 0175. On teh laptop, the top numberic keys do nto return any values.
  • ketan_rander Jul 14, 2009
    Thx. Any idea why the top keys would not work? Changing the num lock key back and forth is bit cumbersome.
  • 285 Answers
There should be a key on your laptop that enables NUMLOCK.
Some of the keys on the keyboard, on the right upper side, should also have numbers on them. When numlock is enabled, you can use the ALT code using these numbers, and it should work.
If not, please post back here and I'll find another solution for you.
Posted on Jul 14, 2009
How do I type accents on a laptop without a secondary numeric keypad?
Type character map in your windows search box and select the font you require. You may need to download the windows language pack for each language you use.
Oct 26, 2014 | Compaq Computers & Internet
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
I use a lap top, IBM ThinkPad, that has been in my docking station for a long time and it works fine in the docking station with the external key board and screen. I recently took it out of the docking...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Dec 03, 2012 | IBM ThinkPad T41 Notebook
I dont know how to access all of the symbols that are on a key e.g. one key has a question mark, a slash and two other symbols, one is blue and the other is green
You use teh shift key and the [FN] key to access these extra sets of characters. If it is basically a circle around a symbol then press and Hold the [FN] key while pressing the key you want. If it is the ?,,{,},:," or any of the symbols on the upper part of the number keys at the top of the keyboard just press and hold the shift key while pressing the key.
Jul 24, 2011 | Computers & Internet
How I can know the model name of Acer Power Series desktop Whose SN. is AWP27BS0495365516LE AND BIOS: RO1.B4/W0#2010
AWP27BS0495365516LE is nto the serial number.
acer serial numbers are 11 characters by a bar code.
once you get the actual serial number you can use the acer warranty tool
http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Activate%20Your%20Acer%20Advantage
Mar 30, 2011 | Acer Computers & Internet
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
How to type caracter on top of letter n
Under Windows hold down ALT while typing the appropriate number code on your numeric keypad to create characters with tilde accent marks. For Windows, the number codes for the upper case letters are:
ã 0195
ñ 0209
õ 0213
For Windows, the number codes for the lower case letters are:
ã 0227
ñ 0241
õ 0245
Nov 30, 2009 | Toshiba Satellite A105 Notebook
Don't know how to type the third symbol on a keyboard key e.g. the little subtraction symbol on the right of the colon/semicolon is what I'm going for
Hello there brennerc.
Here's your GEEK-steer ...
Based on your description I'm not sure which character that is. Are you sure it's located on a standard keyboard? If not, it's what's known as an "extended" character, with which you'll need your Windows "Character Map" accessory to help you locate.
[Start > Accessories > System Tools > Character Map]
... or ...
[Start > Run... > type "charmap.exe" (without quotes), then Enter]
TIPS:
  • Clicking on any character's (square) will initiate a perpetually zoomed popup to help you see it better.
  • Once you find desired character, double-click (or select button) it to place it into the "characters to copy" field, where you can then "copy" (button) it, and then paste wherever desired.
Good luck, and thanks in advance for posting back ...
  • to let me (and others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed – Craig
Sep 27, 2009 | Dell Inspiron E1505 Notebook
I want to get a wep key for my router model wrt54g-v8 serial number cdff1g5b8259
You can create a WEP easily.
In the router setup, when you enable wireless security, you select WEP, then you can use any alpha numerics you want for the key.
for 64bit encryption, you can use a 10 digit key. ( I suggest an old phone number as it is 10 digits, hard to figure out and generally easy to remember) 128 Bit encryption is a 26 character key which is hard to guess, but hard to remember too.)
Once the key is set in the router and saved, you merely View Wireless Networks, select you router and type in teh key when prompted for the key.
Sep 13, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
