Question about Adtran NetVanta 3200 Router
Amber light on Adtran 3200 router. This router
Amber light on Adtran 3200 router. This router provides internet access via a T1.
4 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Posted on Sep 20, 2008
ted1430
  • 339 Answers
SOURCE: Can't access the internet..
I believe that what you want to do is use DHCP which can assign an IP address, gateway, and DNS server addresses to computers on your network automatically. Many DSL routers include this functionality.
Normally a T1 router does not handle DHCP and the 2824 like most switches does not either. It can act as a DHCP relay but that's a feature typically used for remote locations of larger networks.
There are a couple of different ways to handle this.
1. You may be able to use your old DSL router for this role but only if it will allow you to set the gateway address to an address that doesn't match its own, i.e. the gateway address given to all clients by DHCP must be the internal address of the ADTRAN router.
2. If you have a server like MS Small Business Server then it can handle the DHCP.
3. If neither of the above are practical, you can install 3rd party DHCP server software on a PC. Here's a link to some info on doing this for windows: http://www.tomshardware.com/forum/13577-43-dhcp-server-windows Be aware that if the machine serving DHCP goes down, so will your network after a period of time.
4. I don't recommend using APIPA which is the last ditch method of automatically assigning a 169.254.0.0 network address to PCs when a DHCP server can't be found. You could make this work by giving the router an internal address on the 169.254.0,0 network but you would need to manually configure the gateway and DNS server addresses to make this work.
Regardless of how you handle this, be careful to use a private address range for your side of the router. For a network your size you would normally assign a 192.168.0.0 address with a subnet mask of 255.255.255.0
Posted on May 18, 2009
JaxPlanet
  • 922 Answers
SOURCE: Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Posted on Jan 27, 2010
Don;t know ip adress adtran612
Maybe the user manual you can find at http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man will shed a light on your problem ?
You may try, with a computer successfully hooked up to the router, to type ipconfig /all in the Command prompt. If your router's DHCP is on, you should get it's IP address in the "Default Gateway"
May 13, 2011 | Adtran Total Access 612, T1 ATM with DSX-1...
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Password apparently lost on Netvana 3200 - any hidden reset?
http://kb.adtran.com/display/2n/articleDirect/index.asp?aid=1786&r=0.6352198
connect console cable
Bootstrap# bypass passwords
Bootstrap# boot
Oct 20, 2009 | Adtran NetVanta 3200 Router
Setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
Aug 28, 2009 | Adtran NetVanta 3200 Router
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Cctv remote view/ adtran total access 900e
Carl
Sep 19, 2008 | Computers & Internet
Adtran Atlas 550 alternatives
1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps I recommend a 1721 2: If this would not be an option, what Cisco box would provide the needed termination/routing I recommend a 1721 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device. It depends on the topology of how your sites are interconnected to each other. Please describe in greater detail.
Apr 30, 2007 | Adtran Atlas 550 Router
Adtran NetVanta 3200 Router Logo
570 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
