Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
It won't stay running. have cleaned the gas tank and it just had a tune up. runs fine then gets rough and quits. If I push the bulb it smooths out and runs fine for a couple of minutes and then begins hesitating again. Now today it ran for about 15 min. and now it won't start. It wants to. runs for a couple of seconds 5-10 and then quits.
    President:
  • 1,129 Answers
Remove the float bowl and empty the contents out clean and replace
Posted on Jul 15, 2009
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
I have a sears 247 889571 24" snow blower. Start fine. Runs rough, like the choke is on. Choke is off. Fresh gas (ran it dry last spring). Ran 1 tank through with it running very rough. Just as it ran out...
You ran it dry at some point. Gas tanks collect crud and water at the bottom over time and this may have been sucked up into the fuel filter or carb. Clean or replace fuel filter, then remove and carefully strip apart and clean all parts of the carb be gentle with brass and any moving parts in the carb, clean with plastic tools.
Dec 14, 2013 | managemylife.com
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
How to tune and adjust carb settings on Lawnboy 2 cycle, 6.5 Duraforce slver pro engine? Throttle appears good at high throttle position but is not smooth throughout range and rough at low throttle...
First remove the inline fuel filter in the tank and replace it, before adjusting the carburetor. Also Be sure the linkage from the governor and to the engine has not broken or fallen off, next check the fuel pump bulb by removing the air cleaner and pushing the bulb in if you see a stream of fuel each time you push the button it's fine otherwise the check valve may be dirty and you will have to clean it to fix the problem. Also make sure the air cleaner is clean. After you check these items then you can adjust the fuel mixture screws turning the air mix valve firs and getting the motor to smooth out at low speed. Turn 1/8 of a turn at a time till you get the desired running range. Also check that the spark plug is nor dirty if it is clean and re-gap it if the electrode is worn out then replace the plug.
Sep 23, 2009 | Garden
Hard start
remove the carb and take the fuel bowl off ; soak it in gas for a few days; clean it good with carb cleaner spray in every hole using the straw; reassemble; clean fuel tank; add fresh gas. If this dont do it , you may have to adjust the carb ,turning the screws 1/4 of a turn at the time til you get it running and then fine tune it
Jun 10, 2009 | Poulan "Poulan" Push Mower
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
441 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
