Question about Nokia 6300 Cell Phone
My 6300i gets stuck at switch on. The screen flashes, the keyboard lights up and then it goes dead...occasionally it gets as far as asking for my pin number...Any help appreciated as I haven't backed up my contacts list!!!
2006 PT Cruiser Limited Turbo, check engine light on and flashed various codes. P0882, P0714, P0700, P01603, P0551, P0100 and P0101. Can i do pin test?
Code 100 and 101 are for problems with the Mass air flow meter.
Have you checked it ?
You can pin test the computer but you may need a shop manual to get the wiring diagrams.
Nov 15, 2015 | Cars & Trucks
HP IQ772 power but no boot
all PC's fail. (Virus is #1 )
what OS (xp,vista, w7) ?
is this PC in UK, England?
HP shows, CIRCA 2007 build, (1st) and is near out of support)
sure... you skipped the first steps.
1: battery out, get it out of the pc.
2: use only he a.c line pack ,
3 it has PSU are all power pins reading correct voltage? must
4: if above ok, the BIOS works, on all systems,
GET BIOS to work first.
do you know your BIOS hot keys, its very important to learn this first
if working on any PC made ever. 1981 to now.
see this yet, the BOOKS
http://support.hp.com/us-en/product/HP%20TouchSmart%20IQ700%20Desktop%20PC%20series/3351217/model/3561184/manuals?jumpid=reg_r1002_usen_s-001_title_r0001
best is not to pull any Cmos battery , just use a volt meter
there, 3v is good, 2v bad. see? or scramble all BIOS setting
including boot drive... arg.
this box has no standard VGA 15pin jack on rear, making
tests with external display hard
use a flashlight pointed at screen see any data
if yes the blacklight in the LCD is dead. (BIOS screens dead)
does boot up, F11 bring up windoz recoverY.
odd machine, wireless mouse and keyboard
the latter begs the question gee how can we get to BIOS
lacking a keyboard, driver in BIOS ROM.
curious ,,, on line i see no body getting BIOS screens.
fresh battery in keyboard,
what happens here.
If the hard drive errors happen before you can get to a recovery screen, try this:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter .
  4. Select a keyboard layout that matches your country/region and click Next .
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field (press Enter if you didn't put in a password) and then click OK .
    A System Recovery Options window opens.
  7. Click Command Prompt .
  8. At the prompt enter: c:
  9. At the c prompt, enter: chkdsk /b
  10. If a message opens saying you need to forcibly dismount the drive say yes.
  11. When it is done, try to do an F11 recovery again.
black screen has many causes.
if its not just the back light dead, use a flash light first
get BIOS to work, do you get F8 or F11 screens
this is key to solving the true cause on all PCs.
one can use a USB keyboard if yous dies.
ask here , on the real forum.
http://h30434.www3.hp.com/t5/Desktop-Video-Display-and-Touch/IQ772-Boot-Up-Problems/td-p/64527
i read your 2 users guides, no one word on BIOS
that is BS. and due to now rear VGA port (has some mini bs jack)
you cant see if the PC is dead or just the silly display or GPU chip dead.,
a preplexing box, i never buy those i get real DT or top HP laptops.
all in one boxes are custom, and tricky to fix.
for sure the nasty VGA trick missing, JACK
Mar 17, 2017 | HP TouchSmart Computers & Internet
I have hp pavilion dv2000, when I plug in dc cord it switches on without pressing power switch. Than I'm able to switch it off and on. All lights on panel and motherboard switch on also. CPU fan switches...
dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 16, 2017 | HP 417035-001 - HP Pavilion dv2000 Series...
Omnibook xe4500 long beep and now will not post bios. This happend when I was trying to boot to the DVD to reload the OS recovery disk. All the lights above the left side of the keyboard are lit up with...
screen never shows words, ever, does external screen work
at VGA port?
no bios does not just bug out , like ELVIS.
its ROM , ROW will not forget, (99.999999%) of the time.
good for 25+ years, by DESIGN.
unless humpty is pushed by geeks playing bios flash games.
this notbook is old , Pentium 4 , square screen , omg, old
512kb mem. ouch
HDD 30GB. (tiny)
first is what, try this
1: battery out. (big battery, ) take it out.
2: coin cell 3v not 2v, or its bad. replace coin, as all this old are bad.
3: power pack good. must put out full 19vdc voltage , does it? now.
4: BIOS hot keys work, (mine is ESC , key) is yours?
5 still no bios. does a flash light pointed at screen show data there?
yes/ no/. yes, back lamp burned out (or the DC/DC inverter card)
no screens, black screens still...
6: still dead, remove HDD, and DVD. drive. still dead.?BIOS> get BIOS working first. use the hot key.
remove all; easy things, even USB things.
7: remove all extra memory, RAM, if 2 sticks try 1. then run other by self. if runs now, ram removed is bad.
there is more, there are over 3million transistors there.
see black screen #1 here. goes into all steps, all paths for dead.
http://pcdied.com/
Apr 17, 2017 | HP OmniBook XE4500 Notebook
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
IBM R40 Screen Problems
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
Apr 14, 2009 | IBM 11P836402 for ThinkPad R40 Monitor
Leapfrog mouse doesn't respond on screen
We had this happen within the first 30 minutes that we owned the Click Start! It still happens periodically when the kids are using it. For us the LED lights are flashing non-stop on the keyboard, and the mouse does not move the cursor on the screen and you cannot "click" on anything either.
Solution: On the underside of the keyboard is a very tiny hole. Push a pin or a paper clip into it, you'll feel some give in there like you are pushing a button. I push it until the lights stop flashing on the keyboard. It's the reset button. So far this has worked for us everytime.
Good luck.
Jan 18, 2009 | LeapFrog Clickstart My First Computer Pink...
Stuck on Compaq Screen and keyboard dead
I would take the cover off and reseat the memory, video card, and processor. Make sure your fan(s) are working too, and blow any dust out of it if you see a lot of build up.
Dec 25, 2008 | HP Compaq Presario SR1720NX (EL435AA) PC...
No response from Monitor, Mouse and Keyboard
Definitely a "faulty" motherboard. If fans on PC do not turn, no lights come on and dead screen.
If lights come on, and fans turn, try to reset the BIOS by removing your CMOS (and setting the jumper to clear for about 5 minutes, then put the jumper to normal again) battery for 5 minutes.
Sometimes the bios just "stuffs" up and you'll get no response from your pc at all. So all you do is "CLEAR THE CMOS/BIOS"
Apr 16, 2008 | Dell Dimension 3000 PC Desktop
Extra rinse light flashes
make sure none of the option buttons are stuck in if on is simply run a pin round the outer edge to release it
Sep 16, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Nokia 6300 Cell Phone Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
