The water stinks! It smells like rotten sewage when it is washing! I opened up the drain on the front bottom right, but it hasn't helped at all! Once my towels are wet after using, they smell too!
  • 583 Answers
Problem: stinking Cause: Possible one or more of the following:
1. Fabric softener build-up at the entrance to the coin trap.
2. Fabric fibers or other materials caught between the spin tub or other tub.
3. Detergent and/or fabric softener build-up in the dispenser drawer.
4. Iron, manganese or sulfur in the water supply.
5. Frequent use of cold-water washes is not allowing detergent to dissolve completely.
Solution: To determine if fabric softener build-up is at the entrance to the coin trap, remove the front service panel. Then remove the coin trap hose from the tub. If this is the source of the odor, the inner ridges of the drain trap will be covered with thick globs of fabric softener. In this case, a bottle brush (or a condenser coil brush) can be used to clean between the front of the outer shell and the spin tub. If there is nothing between the tubs or around the opening of the coin trap hose, the following suggestions may be provided to the user/homeowner to try remove odors from the washer:
~ Remove and clean the dispenser drawer with hot tap water.
~ Clean the drawer opening recess with a small brush dipped in hot water/chlorine bleach solution.
~ Clean around the door opening, glass, and bellows, area with a hot water/chlorine bleach solution.
~ Wipe the drum with a non-abrasive cleaner and rinse well.
~ Add one cup of liquid bleach to the empty tub and run through one regular wash cycle using the hot water setting.
~ Add one package of GLISTEN (P/N 5303319027) to the empty tub and run a regular wash cycle using HOT water. You can also use GLISTEN to clean the bellows and door area.
~ If no small children are present in the household, leave the door ajar after each washing to allow air to enter and dissipate moisture. Note: An open door could entice children to hang on the door or crawl inside the washer.
Occasionally use warm or hot water settings for your wash. This will help eliminate animal fat residue found in some detergents that may contribute to odors.
Washer smells foul...this is often a build up of soap, water, too many chemicals and this has left a residue, and the mildew moves right in and it stinks. This builds up is often on the inside of the outer tank - picture help.
Many times that this happens is when people use to much soap and then they only do laundry once a week.
One good solution to help your odor problem...it works well...in a top loader I recommend 2 cups of cascade and 2 cups of bleach, fill your machine with hot water and let it agitate. At the end of the agitation/wash cycle, let the machine sit and soak for about 10-15 minutes to work on your scum, then close the lid and let it complete. Next load run whites to be safe all bleach is out. This should help.
On some really bad odor problems, you may have to remove the inner basket to scrap off the build up from the inside of the outer tank. You may will need special tools to remove the inner basket.
Fabric softener is also nasty for building up inside and under the agitator.
It is recommended to use half to a quarter of the detergent that the package recommends.
Other things that may help, leave the washer lid open between laundry days. Never cover your washing machine with those plastic covers.
ODORS IN DUET HE3 & HE4 WASHERS CLEAN OUT PROCEDURE
NOTE: Make sure that you read these instructions completely before beginning the clean out process.
1. Open the washer door and remove any clothing or items from the washer.
2. Inspect the gray colored seal/bellow between the door opening and the basket for stained areas. Pull back the seal/bellow to inspect areas under the seal/bellow.
3. If stained areas are found, wipe down these areas of the bellows using the following procedure:
a) Mix a dilute solution of liquid chlorine bleach and water (3/4-cup bleach in
1 gallon of warm tap water).
b) Wipe the seal/bellow area with the dilute solution.
c) Let stand 5 minutes.
d) Wipe down area thoroughly with a dry cloth and let the washer interior air dry.
e) Please note:
- Do not use bleach at full strength for cleaning surfaces.
- The use of rubber gloves is recommended when cleaning for prolonged periods.
4. To begin the clean out cycle, do the following:
a) Open the washer door and remove any clothing or items from the washer.
b) Be sure door is closed.
c) Open the dispenser drawer and remove the detergent divider from the main wash detergent compartment. See the Use and Care Guide for instructions. No additives will be added at this time. You will be required to add them at a later step.
- For Whirlpool Duet, select the �Power� button.
- For Kenmore Elite HE products, move to the next step.
d) Select the �Normal� wash cycle.
e) Select the hottest wash water temperature available, (not all temperatures will be available).
f) Select the highest spin speed available.
g) Select the additional or 2nd Rinse option (if available).
h) Press and hold the �Start� key for 2 seconds. The door will lock and filling will begin. NOTE: The water will dispense for a moment, then the door will unlock and re-lock and the cycle will continue.
i) Once the filling has begun again, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the main wash detergent compartment.
The liquid chlorine bleach should immediately flow through the dispenser.
NOTE: Do not add any detergent to this clean out cycle. Use of more than 1 cup of bleach per month will cause product damage over time. Addition of bleach without immediately starting the cycle will cause product damage over time.
Posted on Jul 14, 2009
Rotten egg smell/sewage smell in restaurant
check for dead rodents in the ceiling. Have a plumber check for blocked /leaking drains especially around the dish washer drains . If you have had pest exterminators in lately then something may have taken the bait . IT will be best to get in professionals to remove the smell as quickly as possible as to customers a smelly restaurant is equal to bad hygiene and food poisoning.
Feb 20, 2014 | Home
Water smells like sewage
The drain is connected to the sewage system, so the smell could come from there, install a trap valve
Mar 29, 2013 | H2O Audio H20 Vac Turbo Water Filtration...
Hi, Every time I turn on our front load washing machine it stinks like sewage or something rotten. Now, even if the machine is not on, the laundry room still stinks. I little while ago we painted the...
Does it drain into a trap? It sounds like you may not have a trap fitted and the smell from the drains is coming through the outlet pipe?s
Jan 11, 2011 | Washing Machines
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi my zanussi 1221w washing machine stinks. I regularly empty and check the pump filter and the emergency drain. I have used calgon, bleach 95 degree empty wash cycle but it smells like there is a dirty...
check the door boot just inside the door for dark spots on the gray rubber boot and the drain hole in the boot it can grow mold where the water stands in it from previous washings and this mold will smell like raw sewage from all the soap and softener that aids in mold growth
Jul 22, 2010 | Zanussi FC1200W Front Load Washer
Smells
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes.
Mar 18, 2009 | Candy DQW150 Front Load Washer / Dryer
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Jul 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Clothes stink after being washed
run a empty load of just bleach and keep the door seal wiped down plus when your not using it leave the door open
Jan 11, 2008 | Washing Machines
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
