Question about Microsoft LifeChat™ LX-3000 Headset
No sound from LX-3000
I think the problem might come from the audio program which came with the motherboard. It is smart enough when you plug in a mic or a set of speakers into a normal jack but there does not seem to be an option for the sound program to pick up USB signals. Although Win XP figures out what it is.
    President:
  • 2,777 Answers
You will need to change your default audio output device to be the USB headset. You can do this under Sounds and Audio Devices in the control panel. Change it from your regular sound card to the USB headphones. They should be on a drop down list.
Hope this helps
Posted on Jul 14, 2009
My mic does not work on my microsoft lx-1000 head set, the audio works through the earpiece but no the mic, i've gone to set up a mic in the windows 7 settings but it does not hear me. I had a...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps W7
Jul 30, 2011 | Computers & Internet
How do I get the headset, set up so I can use it. I plug it into my computer and nothing happens. Do I have to download something first? There are no directions with it. And if I have to download it, how...
There is no need to dodownload something. assuming that you have already installed correctly the audio card drivers. If you are able to hear sounds from the speakers, the audio card is installed correctly. So plug the green male jack to the green female jack and the red male one at the red female jack (if your headset has no mic, is only headphones, there isn't any red jack). From now on you must be able to hear sounds from the headphones and talk to the mic for someone to listen.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | Microsoft LifeChat™ LX-3000 Headset
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Is it possible to use MS LifeChat LX 300 on the playstation 2 ??
first of all your ps2 does not support mic. so, if u want only sound, i suggest to buy phone jack to audio plug splitter...that thing is looks like as it can match your headset jack at first end and second end is two color jack (white n red) that can match to your ps2...you can buy it in audio shop...it is cheaper...
May 27, 2009 | Microsoft LifeChat™ LX-3000 Headset
Headset isn't recognized by computer and audio doesn't go through headset
With the infamous Vista, try:
Start --> Control panel --> Hardware and sound --> Sound --> Audio devices admin [I have a Spanish OS, I hope it is the same in the English version], then assign as default device the headset.
With Skype and other sw, you have to specifically pick the lx-3000 as the device that will be used as audio device (and the same has to be done to use the mic).
Pretty cumbersome....
Apr 18, 2009 | Microsoft LifeChat™ LX-3000 Headset
Lifechat LX-3000 refuses to let me speak
I had the same problem which I traced to a manufacturing fault. I had to break into the control box halfway along the cable (you will defintiely void warranty doing this!) The cable connection from the headphone to the control circuit was not properley terminated (some cable insulation was melted through to bare wires). You have to re-terminate this cable so you need skills cutting/stripping wires and resoldering, and if you attempt any of this don't expect to be able to complain or ask for a replacement under warranty.
Apr 10, 2009 | Microsoft LifeChat™ LX-3000 Headset
Microphone not working ?
I have seen situations in the past where a woman especially would not modulate her voice well enough to make good sound on her mic, other then that, make sure your mic volume is set fairly high. Also if the situation is not cleared by the previous two suggestions look for newer audio drivers for your system ( whatever that may be ), a.k.a. motherboard audio driver or sound card drivers depending on what hardware you have installed
May 26, 2008 | Microsoft LifeCam VX-3000 Web Camera
Realtek audio device with sound effect menager
First thing is first, there should be 3 audio jack inputs. Line in, Line out and Mic. Make sure you are plugged into the Mic input.
Next if you are running windows XP check to make sure the Microphone volume is not muted and turned up. Do this by going to control panel --> Sound and Audio Devices --> volume tab --> Advanced button. The Microphone volume should be there if not select file --> properties and make sure microphone is checked. It should then appear on the volume controls.
This should take care of it if not what program are you using the mic with?
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Open Questions:
See all Microsoft LifeChat™ LX-3000 Headset Questions
Microsoft LifeChat™ LX-3000 Headset Logo
1,724 people viewed this question
Top Microsoft Radio Communications Experts
Adrian W
Adrian W
Level 1 Expert
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
