Question about McCulloch FH160G Pressure Washer
Have hole in water hose to wand. can it be fixed
Have hole in water hose to wand. can it be fixed or can I get a replacment? Den.
  • 867 Answers
You cannot fix the leak, you must replace the hose.
Posted on Jul 14, 2009
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Why doesn't it work when the water hose is attached?
Pressure washers can only be started/run with water attached. No water burned out pump in 5 seconds! If pump puts out high pressure water without wand/hose attached, bad wand or hose, if not bad pump. Replace pump.
Apr 05, 2016 | Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Little water pressure from wand. The pressure does increase and decreasefrom little to nothing and only from one hole.
Try removing tip on wand 9 out of 10 times sand or grit will plug spray orifice
Mar 27, 2017 | Toto Home
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
When pressure washer is running no water is
Most of the time the problem is just debris in the spray nozzle. The hole is very small and it doesn't take much to clog it. If you can remove the nozzle, just take a pin or small piece of wire & poke it through the hole from the front of the nozzle and rinse it off with the hose. If the nozzle cannot be removed, just take the lance apart in the middle and do the same.
Feb 05, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
McCulloch FH160G Pressure Washer Logo
130 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
