I have an Armstrong D4100 amp. Armstrong offers no support, parts or drawings for this model. In the unit, in the power circuit, I have an IC chip that is burned. I cannot id the chip. The board location is IC901. I am looking for schematics for this unit, or an ID on the chip.
  • duane_newell Jul 17, 2009
    The part I amlooking for is on the power board. The chip has 4 pins on one side, and 3 pins on the other. I found the top of the chip that was blown off in one piece. IC109 labeled as follows:
    K015
    TOP233P
    12600A
    The logo looks like a thick I.
  • Rommel Cana
    Rommel Cana May 11, 2010
    hi, can you give me more description about IC901? how many pins does it have? is it part of the output stage? is it part of the power supply? if it is part of the main amplifier then , try to look in the other channel , if that part is common to both the 2 main amplifier, i presume it is part of the power supply. if you could possibly identify what stage that might be, might help I'm still looking for your schematics, but no luck yet, still looking
StuartB
  • 807 Answers
SOURCE: Parts for Technics SE A900S Audio Power Amplifier
Here ya go.
http://www.vancebaldwin.com/products/?MSCAN7062
Posted on Mar 13, 2008
  • 1894 Answers
SOURCE: Behringer Vintiger GM110 guitar amplifier Output pcb board
best idea is to buy a old one from ebay and use the board alone from it
Posted on May 23, 2008
  • 5 Answers
SOURCE: fujitsu asu18c1 mini split ah
change the fuse donot operate the unit and change the thyristor
Posted on Feb 24, 2009
  • 4234 Answers
SOURCE: Looking for circuit schematic for a Teac AG-7D.
This unit has detected a problem in the output section and the protection circuit is preventing the output relay from turning on. In most cases this is due to shorted output transistors which will need to be replaced. If you have a multimeter, set it to read DC volts and measure the voltage on the three legs of one of the output transistors. You should read .6V, 40V or so and 0.0. I suspect that you will read 40V on two fo the three legs. If so, that is your problem. Please note that the actual reading for the higher voltage may be something other than 40. I don't have the service manual for this model, so I don't know the exact voltage. It will be anywhere from 35V-75V depending upon the actual design and output transistors.
I am not aware of the availability of schematics for this unit, but any shop that works on audio gear should be able to repair this without them.
Dan
Posted on Mar 09, 2009
projdoc
  • 2236 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
I need to install after market ignition switch into 1998 pathfinder ...would like to know color codes and placement of wires to new switch.
Hello Victor Sullivan,
Before I would endure the cost of the FACTORY drawings... I would try the FREE database offered by BBB Industries ...
a well known automotive equipment supplier
(registration required).
They offer popular AMERICAN market vehicles...
Circuit Drawings and TECHNICAL Service Bulletins...
They are well known to your mechanics & auto parts
RETAILERS...
look-out below
BBB Industries Premium Alternators Starters Power Steering Products
Dec 03, 2016 | Cars & Trucks
I would like to know the electrical requirements.( voltage and amperage) Does it plug in or is it hard wired? If the power goes out is the hot water also out? thankyou
Are you asking about tankless gas or tankless electric?
You posted under Tankless gas water heater: gas type tankless plugs into standard 120Volt household outlet to power circuit board. You need larger gas line than used for tank-type gas water heater.
If you are asking about volt and amp draw of Tankless electric, then that depends on specific model number.
For example, if each tankless element draws 3500Watts, and unit has 3 elements, you will need 3 additional 20 amp 240Volt circuit breakers. Volts x amps = watts. 3500 watts divided by 240Volts = 14.58 amps. At full blast, this unit would draw 43.75 amps and will cost more to operate yearly than tank-type electric water heater. If unit has 4500 watts elements, then it will draw 56 amps at full blast, and use a good percentage of household power.
Tankless water heaters have no hot water in power outage. This is true for gas and electric models.
Additional resources:
http://waterheatertimer.org/images/Compare-water-heater-parts-650.jpg
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/pdf/Bradford-White-on-demand-tankless-service-manual.pdf
Aug 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
One channel ceased to work. Found transformer to be bad and replaced it. Turned unit on and the top circuit board at front off unit was getting hot and a burnt odor appeared immediately. Found a...
The part is a 4560 (generic opamp IC. The damaged IC is more likely to be the symptom not the cause Remove the IC and the cap. Replace the cap, but not the IC and measure pins 4 and 8 to ground. These should be the power inputs and measure +/- 5 thru 12 volts. They should be equal but opposite. Should htey be different, check the power supplies or any filter caps.
Update this with the results.
Thanks,
Dan
Mar 22, 2011 | DBX 2231 Home Equalizer
I have a Fisher Stereo Amp Model CA-9025 thats not producing any sound. I have the cabinet off the unit, the unit will turn on, but won't produce any sound. Any other fuses to check or other ideas?
These units use STK amp pac ICs (large black part attached to the rear heatsink). In many cases, this IC is defective. It is possible that there is a problem with the voltage regulator circuit, but that is less likely. This IC needs to be replaced. Expect to pay in the $50 range (or more) for the part.
Dan
Mar 12, 2011 | Sony Audio Players & Recorders
Need assistance in getting details of part number for power mixer
I tried to post a possible solution and it may have not made it so I will try again.
Download the data sheet for an LM3886.
This chip is used in a lot of linear audio amps in the 50 Watt range.
Download the data sheet and then check if connections on your unit make sense.
Smaller units sometimes use the TDA2050 7 lead TO220 style chip so look at that one in the LM3886 isn't the one.
May 06, 2010 | Music
I have a behringer pmp 880s powered mixer it has a blown IC chip In need the part number.
Please note that there are many chips in the Behringer devices and we can't guess what the chip might be since we have no idea where it is in the unit.
HINT: There are MANY circuits in common in the lines of music equipment. See if the circuit board has a part number as well. The board may be in common with other PMP boards.
Also note the chip location, such as IC12 and also tell the type, Thru hole or surface mount, and the number of leads and ANY number on the chip.
Apr 24, 2010 | Behringer EUROPOWER EP2500 Amplifier
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Thanks,
Dan
Oct 23, 2009 | Audio Players & Recorders
Troubleshooting main board.
Three things to look for in service with LCD monitors,
1 bad capacitors
2 Bad transistors for the back light feeds
3 bad ic pulse chips for the Non function circuit
you will not find schematics unless you peruse the patent office records, reverse engineer the circuits and you will have a schematic
when the main chip fails on the vga board its time to buy a new vga video board,
sounds like your board may be suffering a bad IC telling the main chip the power is OK
let me know how it goes.
Dec 29, 2008 | HP w19 19" LCD Monitor
Batteries in my Rino 120 don't last very long
I believe its 3AA's and it SHOULD last 15 hrs of life. You should probably check the terminal heads and clean them real good you might be shorting somewhere in the connection.
Aug 02, 2007 | Garmin Rino 120 2-Way Radio
 Grubhead
Grubhead
