Question about Hotpoint Aquarius WF210 Front Load Washer
Belt has come off
The belt from my hotpoint aquarius wf210 has completely dropped off. There is no damage to it I just want to know how I can locate the pulleys that I need to pull it round.
  • 108 Answers
I have fitted a replacement belts on a few older machines (Hotpoint WMA series). The procedure is likely to be very similar on yours.
Check your belt for wear - if it fits really easily it may already be stretched and will come off again quickly. A replacement is less than £20.
1/ Turn off power and disconnect.
2/ Check you have Turned off power and disconnect.!
3/ You best course of action is to open the lid. You will need tools. Torx set etc. Look for little finger nail size plastic covers over torx heads on the sides. Remove lid (push back and lift).
Once opened you will see large drive wheel connected to the back of the drum and the drive motor is at the bottom. Use a torch if its dark!. You will need to ensure the belt is fixed around both of these. This is not easy to do. And try not to pinch your fingers.
It may help to remove the concrete block on top of the drum to give you more room. Use large spanner. (You must remember exactly how this is fitted to refit)
4/ Dangle the belt around the motor spindle and lightly pull it to stop it sliding off. Next pull the belt round one side of the drum wheel. Gently rotate the drum until the belt is looped round the drum wheel and the drive motor at the same time. Sounds easy? it's not.
Regards
Posted on Feb 25, 2008
  • fardap Sep 01, 2010
    thank you for your advice ,i did exactly what you said and still trying , it really is not eas to do, but at least i am on the right track thank you
What does f-10 mean on hotpoint w630 washer
and may need replacing. Check the plastic tube has not come off the sensor or has become damaged or kinked as this would cause the same error.
Aug 16, 2012 | Hotpoint Aquarius WF210 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 filter location?
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Require a manual for Hotpoint Aquarius WF210 washing machine
You cannot download a repair manual on line, you have to purchase them from Hotpoint,
However, if it is a user manual you require, then go to:
WWW.HOTPOINT.CO.UK
Click on after sales, and then on download instruction books, put your model in the box, and then you can download to your computer. or to your printer.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
How do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
