Question about Hoover S3639 WindTunnel Bagged Canister Vacuum
I plugged this vacuum in - started it, has good
I plugged this vacuum in - started it, had good suction, but it smokes and smells like it's burning. turned it off - should I just throw it away?
  • 867 Answers
Seens like beater brush belt dirty
Posted on Jul 14, 2009
My vax hoover burning herself what can ido nw ?
Sounds like unit could be plugged some where. If the motor is over worked that will cause it to over heat hence the smell. If it keeps smelling like this you may burn the motor up. Also see if there is suction when you start it up. If not it may be plugged somewhere.
If it's not plugged could be a bad bearing. See if the belts are working ok as well
Jun 27, 2014 | Hoover U5753-900 WindTunnel Bagless...
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
I have a Eureka Power Plus vacuum, model 4702, type A. To start off, it never really had great suction. Marginal at best. Then today I was vacuuming and smelled something burning and turned off the...
If it is the motor it may smell electrical and the motor is likely shot. It's very possible it needs a new belt. Your model has a stretch belt and they should be replaced at least every six months (even if it's never been used) because belts need to be stretched so far to be installed they will lose elasticity and slip on the shaft which can cause the belt to melt.
Jun 26, 2017 | Vacuums
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Not suctioning/
i would change the belt and filter.( belts need to be changed on average every 6 months). now if you smell a burn like an electrical smell the motor is gone.
Jul 19, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Burning smell
I had burning smell and some visible smoke which I tracked down to the handle area. The mains socket at the bottom of the handle had burned out. When I pulled the plug out I noticed that the prongs were blackened and scorched. I will replace the socket.
Nov 02, 2008 | Oreck XL Ultra Bagged Upright Vacuum
No suction, burning smell, expells dust
If by "suction" you mean it's not picking up dirt and debris on carpet, odds are your belt needs replacement, and the belt has burned, causing the burning smell. Ensure that your brushroll spins free, and replace the belt. (Belts should be replaced in any vacuum with a rubber belt every 3-6 months, regardless of use.)
If you mean that you are not having any airflow at the end of the hose, you most likely have a clog in the main hose and the burning smell is caused by your motor overheating. Ensure that there is nothing blocking the hoses.
If you have suction in the hose, and your brushroll is turning, there may be a clog in the head area behind the brushroll. Look in the hose that your wand plugs into, and ensure that it is also clear.
-R
Aug 05, 2008 | Eureka Vacuums
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover S3639 WindTunnel Bagged Canister Vacuum Logo
162 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
