Air conditonar freezes up - Heating & Cooling
  • 355 Answers
An air conditioner produces water in the course of chilling your air. If this water does not vent properly off the coils you get frost or worse yet ice. Turn the unit off and let the ice completely melt off. You might not be allowing the unit to completely thaw. Let it sit for a good day or so. Make sure the ice is completely gone. If this does not work either the coils need to be cleaned or the unit has a vapor leak.
regards
Posted on Jul 14, 2009
Fix freeze up
There is a reason they freeze up 1. low on freon..2 evaporator coil needs cleaning(inside coil)..3. very dirty air filter, any one of these for a an air conditioner may freeze up... due to a number of other reasons. The most common reason for an air conditioner to freeze up is low on refrigerant.
Jun 27, 2015 | Heating & Cooling
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Rheem 13AJA30A01 freezing
You have one of three problems. First freezing can be an air flow problem. Air flow could be causes by using the new pleated air filters. The best one still blocks >35 % of the air flow. The best air filter for home ac units is still the blue mesh type Ace hardware sells. If you have a good filter then you need to check out the inlet side of your evaporator to see how clogged the air inlet is. If it is dirty the air flow is reduced and if reduced enough, the evaporator can freeze solid all the way out to the compressor. The second cause for freezing is a bad or improperly operating blower motor. The third possible cause for freezing is the metering device not functioning properly and metering to much.
Jun 14, 2014 | Rheem 13AJA30A01 2.5 Ton 13 SEER R22 Air...
The unit keeps freezing up solid even on energysaver
Change or clean the filter and clean both coils, no air flow or reduced air flow, the coil will freeze. It will also freeze if its set to cold 72 min. setting. Example if your room temp is 72 degrees, than the air will be 52, and the coil temp is 32 degrees, any moisture will freeze. Hope this helps
Jul 02, 2011 | Whirlpool Heating & Cooling
My air condtioning unit is a GE unfortunately I can't se what btu but ev ry our the coil freezes and its spitting out water. Room size.
clean the coils its freezing up because the air flow is restricted because of dirty coil or filter after cleaning the coils and it still freezing up then it will need some refrigerant aka freon
Aug 19, 2010 | GE Built-In Room Air Heat Cool Air...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Jun 19, 2009 | Whirlwind FH-778 Air Conditioner
Inside unit freezing
There are varius items that make the unit inside (air handler) freezes up .If the fan motor in the air handler doesn't work it'llice up.If the filter is dirty it'llfreezes up. If the coil in the air handler is dirty it will freezes up.And if the unit is low in refrigerant(freon) it'll ice up.If is low in gas means there's a leak and before recharged it needs to be fixed.
Apr 23, 2009 | Heating & Cooling
Central heat and air freezing up
It is not freezing because it's cold outside,It is freezing due to a problem.
It needs to thawed before it will work,
1st:Check or change the filter if need be.
2nd:Make sure none of the vents are blocked off(especially the return)
3rd:The only way to thaw it when temps are low outside,without being out in the weather is to turn on the air conditioner,You will need to use other means to heat your home until it thaws.
and Please if you use the stove for heating,don't fall asleep with it on.
Jan 17, 2009 | Heating & Cooling
Freezing Up
sounds like air is not flowing properly thru the a/c. if there is a filter you can pull out remove it and clean it.
Robert
Sep 01, 2008 | Fedders A6X05F2D Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
