Question about Panasonic TH-42PHD7UY 42 in. HDTV-Ready Plasma Television
I have a TH-42PHD7UY Panasonic Plasma that suddenly has double picture on the screen. For instance, in the menu screen there are two versions of the text offset by about 2 inches down and one inch over. I've tried to adjust this without any luck finding any sort of screen. Is there a setting or is there a part I can replace??
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
SOURCE: Panasonic TH-50PX60U Plasma TV no red color
We had the same problem with a different model plasma tv. My wife tried unplugging the tv for a minute or two, but we still had the same problem. I unplugged the tv and left it unplugged for over 8 hours, then plugged it back in and the problem was fixed.
Posted on Oct 17, 2008
  • 58 Answers
SOURCE: intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Posted on Jun 16, 2009
stonephoenix
  • 563 Answers
SOURCE: Panasonic Plasma screen suddenly has a verticle black line
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 03, 2009
  • 31 Answers
SOURCE: Panasonic TH-50PX60U 50 in. HDTV Plasma
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Posted on Apr 04, 2010
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Jan 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My last question was in reguards to a panasonic th-50px 75u I have small black vertical lines all across the screen and a rainbow effect on the picture all channels and all inputs
Press the menu button on the TV remote and see if the lines are on top of the menu or covered up by the menu. If the lines are covered up by the menu, the issue is being caused by your source device.
Aug 26, 2013 | Panasonic TH-50PX75U Plasma HDTV
Everything is red on my panasonic th-50ph9uk.
I have a Panasonic plasma 55 inch and the screen went green and pink is this fixable
Apr 07, 2013 | Panasonic TH-50PH9UK 50 in. Plasma...
Th-42ph panasonic red light blinks two times
Try changing the fan. Most probably the power is not coming for both the fans. If the fans are working on 12VDC, remove it from the board and try connecting the fan to an external 12V DC observing the polarity. If it works, the power supply is the problem.
Jun 24, 2012 | Panasonic TH-42PHD7UY 42 in. HDTV-Ready...
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Jun 18, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Replace screen
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Mar 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TH-42PHD7UY 42 in. HDTV-Ready Plasma Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
