Question about Sony DAV-S400 System
Speakers stopped working
Sony DAV S400
Speakers have stopped working and the display shows HP [ 2 CH ] and when I press the sound field on the remote it display Headphone Theater or HP Theatre. Is there anyway to get the speaker system working again?
Please help !!!!
2 Suggested Answers
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
nuwan chinth
  • 111 Answers
SOURCE: sound field
bad connection of hedphone output jack socket.can you open the cover for repair that.many tims it should have to change .
Posted on Jan 12, 2009
0 characters
1 Points
Dav dz750k
Check your center channel. Most dialogue is routed to the center channel in surround.
Jul 24, 2013 | Home Theater Systems
Plays for a few minutes and pops and goes off?
Check the connectors on the speakers arent shorting and are connected correctly. A sony downloadable manual is available on the sony website it will tell the correct way to connect speakers. If tht doesnt stop change sound field to 2 channel that worked for me .
Jul 28, 2011 | Sony DAV-DZ30 Hometheater System
Try pressing the mute button on the remote
Jul 29, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound field
Dec 21, 2008 | Sony DAV-C770 System
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Apr 09, 2008 | Sony DAV-S400 System
Sony DAV-S400
You need to get a one off remote control from this company. It works I have unlocked mine.
Dec 04, 2007 | Sony DAV-S400 System
Sound problems on Sony DVD amp
it might have to do with dry joints as noted in other questions
i have once re-soldered all points of the amp PCB and the sound did get better for the right, but still cuts to the left... ima try again tonite
May 31, 2007 | Sony DAV-S400 System
Sony DAV-S400 System Logo
47 people viewed this question
Top Sony Home Theater Systems Experts
Dennis McCollum
Electro Med Services...
Are you a Sony Home Theater System Expert? Answer questions, earn points and help others
