The machine will not agitate, before it stopped it made a high pitch noise off and on and cannot turn the tub
  • yadayada
    yadayada May 11, 2010
    if u don't get the answer u need in a reasonable time try the premium question option.
    Brigadier General:
  • 4,088 Answers
Is this a top loader? Something jamming the under side of the agitator? Remove it to check. If the shaft that drives the agitator is frozen--may be bad bearings (and the source of the noise). If a front loader, the tub main bearing is probably frozen, again the probable source of the noise or maybe the drive belt was slipping.
Posted on Jul 14, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
Wahser makes loud noise trying to stop spin cycle It seemed to spin ok and agitate but made terrible noise when trying to stop
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing. but more than likely its the brakes, or the belt itself ,, a solinoid signals the machine to stop which in turn applies brakes just like a car only smaller, when these wear they tend to do the same as a car and squeal , its just an indication your machine is up for some maintenance,
Jul 25, 2011 | Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Pav3200washer making grinding noise
The tub is supposed to be locked untill the brake is released. When the machine is in the wash mode the tub is locked or else the clothes would all get knotted up. When the motor reverses the brake is released and the tub can turn freely. Check the pump for bad bearing.
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
