Question about RIM BlackBerry Pearl 8100
Water Damage My phone was in my bag during a moment of ridiculous amount of rain, now the buttons won't work.It has happened before but cleared up after i charged it, this time it has completely died! The phone is a Samsung G600.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
You need a new phone.
The liquid has caused circuits on the motherboard inside the phone to become shorted out and inoperable.
Posted on Jul 15, 2009
Piaggio X9 will not start after being in the rain
Hi, Bob moisture, condensation, rain, or bike washing can make the bike run sluggish, not able to rev, and misfire. Older bikes, engine configuration, and exposed electrical components are at the front of the line for acting up. During the diagnostic procedure spray Electrical Contact Cleaner on corroded wire connectors/pins/sockets etc. and apply a liberal amount of "DIELECTRIC" grease to the mating harness/wire connectors. WD40 works great for eliminating suspect areas in your quest to find the real offending gremlin.
For additional insurance you can spray a High Temp Clear Coat on the most vulnerable areas it will work like Scotch Guard does on fabric. Fabricate a rubber or plastic splash guard to deflect water coming off the front wheel getting to the front cylinder spark plugs. The design should be adequate for its purpose with the least amount of airflow restriction to cool the cylinders. The usual suspects are:
1. Air filter soaked with water.
2. Water in the fuel system gas tank and carburetors.
3. Wet ignition coil packs.
4. Spark plug boots wore out or loose allowing water to enter.
5. Spark plug cables old and cracked check for spark leakage in the dark.
6. Spark plug wells filled up and drain holes clogged.
7. Water in a wire harness that has exposed open ends and have a sharp bend or crimp allowing the liquid to form its own pool of potential threats to chaffed wiring.
8. Sensitive fuel tuners and downloaded ECM remaps may get confused with the abnormal cylinder temperature difference in a V-4 engine configuration.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scoot wont start after rain
02 X9 500 rain damage drained battery wont start
Piaggio 633234 Workshop Manual
Piaggio X9 EVOLUTION 500 2004 Parts
PIAGGIO X9 Evolution 500 User Manual
Oct 29, 2017 | Piaggio Motorcycles
My 03 tahoe has a soaking wet driver side floor board. It's rained a ridiculous amount here in MA. Can't find the leak. Shop said I could be the clogged drain hoses for sunroof, but my sunroof doesn't...
Check all rubber seals for wear or breaks (especially the sun roof) and around any glass. That may be why the sun roof doesn't work anyway...water gets in and rusts mechanism. I would start up top first, then work down.
Dec 15, 2014 | Cars & Trucks
2000 Honda CG 125 Cargo stops in the rain and wet conditions
Hi, Anonymous moisture, condensation, rain, or bike washing can make the bike run sluggish, not able to rev, and misfire. Older bikes, engine configuration, and exposed electrical components are at the front of the line for acting up. During the diagnostic procedure spray Electrical Contact Cleaner on corroded wire connectors/pins/sockets etc. and apply a liberal amount of "DIELECTRIC" grease to the mating harness/wire connectors. WD40 works great for eliminating suspect areas in your quest to find the real offending gremlin.
If your bike will not run right or even start after going through the checklist, despair not, letting it sit for a couple of days in a warm environment is like an eviction notice for the Gremlins and then your bike will be back to its old self.
Motorcycle dies in the rain motorcycles
bike won start after heavy rain
CG125 $15
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Jan 14, 2013 | 2000 Honda CG 125 Cargo
Malfunctioning after getting wet due to rain
Take the battery out of your phone and put your phone and the battery inside of a bag full of dry white rice. Seal the bag and leave it for 24-48 hours. After that time, take it out and see if the keys work like normal again. (White rice absorbs moisture quickly and will dry out your phone quickly)
Thanks for asking.
-Josh
Feb 28, 2010 | Sony W595a Cell Phone
Shampoo dripped into cell phone
Unfortunately, water damage is a hardware issue and can't really be solved unless you replace your phone. Water damage is SOMETIMES covered in warranty so be sure to check with Blackberry's customer support.
Jul 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Left in the rain , checked battery , the indicator shows red x's; has there been any damage
Depending on the rain most likely it has suffered water damage. depending on how long it has been since it was left in the rain will depend on if you can get it back to life. Tr to put the phone in a zip lock bag with some rice. let it sit for 24 hours. If there is any moisture left the rice will draw it out. however if it's been a while the water damage may be fatal. If you do get the red blinking light on the top, there still may be hope. There is a way to attempt to reload the OS.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
LG VU screen doesn't work after water damage
I was cleaning the pool when my LG Vu took a dive. I fished it out in about 2 minutes...should have jumped in and it would have been in only seconds.....anyway. Dried it off with my shirt and pushed the lock button to unlock and see the screen...it was on but said Emergency Download. I took the battery out and dried it off also took out the SIM card and memory card. Shook the water out; some drips here and there, fortunately it wasn't water-logged. I let it sit for about an hour and got on the internet to find a remedy. I took advice to put back the memory and SIM cards and plug in to charger....the screen directed me to put in the battery....so far so good. The screen said the battery was charging. I waited patiently for that to finish. When complete, unhooked the charger and hit the unlock button again....what do you know the screen came up! I was estatic! But....the touch screen would not work!! Back on the internet for advice. Decided to do the hair dryer trick. I set the dryer on cool setting and let it blow on the screen. I also opened up the chargers portal and let air blow in there. I took the cover off the back to the battery and let it blow on there....being very careful not to let the battery fall out and not let the phone get hot. I did this for about 30 minutes. There was some fogging of the screen so I focused more on drying the screen with the dryer. The fog cleared up and when I touched the touch screen the top of the screen started working first...bottom still not responding...a little more of the dryer and all worked!!! Screen fogged again in about 20 minutes...dryed it again with dryer and it has been dry ever since. I have gone to every application, etc. on my phone and everything works just like it did before it took a dip! Hope this helps some of you! Key is patience, and some drying with TLC! Best of Luck!
Apr 29, 2009 | LG Vu CU920 Cellular Phone
Water damage
if u have hotair gun so make hit treetment , use liquied flux and at first heat cobba ic thane check if problem will stil there heat flash and cpu
Aug 10, 2007 | Sony Ericsson W700i Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
152 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
