Question about Toshiba Satellite A100-S8111TD Notebook
Computer making weird sounds
I have a satellite A100 laptop and since last two days the laptop is making weird noises. even when i touch the speaker and mic ports it makes a shrill noise and when I tap my fingers on the latptop anywhere other than touchpad and keyboard it the sound reflects in a bea coming out from the speakers. I disabled and reinstalled sound drivers but no go...... confronted some ppl and they said this seems to be an issue of magnetic field.........I was just wondering what this can be. Please help me out as this is damn irritating
  • 883 Answers
Possibly audio feedback, but don't know why. Try disabling the microphone input (for help, post back) as a test. If now gone, re-enable mic but decrease gain slider (for help, post back).
Posted on Nov 17, 2007
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
MY speakers are making weird noise, i have logitech x240 and on youtube i can only listen audio, not voice. Everything is connected but its still making weird noise.
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 26, 2011 | Logitech X-240 Computer Speakers
It loos like I've accdentally uninsatalled my computer speakers or something so what do I do?
go to this toshiba main website and download the sound driver and reinstall it.
just select Toshiba Satellite A100-S8111TD
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Aug 31, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100 Win XP O/S. SHUT DOWN Prob.
sorry to say but sounds like a cooling problem or the bored is bad :(
Dec 29, 2009 | Compaq Presario 1200XL104 Notebook
I bought this toshiba laptop computer about two years ago and apparently my internal speakers are gone. I do not have extended warranty so when I took it back to future shop where I bought it and they sold...
Did you actually have it examined by a technician or did the sound just stop working one day? An update to an audio driver could have caused this. There is really nothing to go out per se on a pair of notebook speakers.
Go to Toshiba's support site: http://www.csd.toshiba.com/ and click 'download' and choose the correct menus to see the downloads for your notebook. Download the 'Audio Driver' and reinstall it. This might magically fix your problem if your mixer settings got messed up and will only put sound out through the headphone jack.
I have never actually seen notebook speakers just stop working for any reason other than liquid damage or a software issue. Very weird.
Oct 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
Laptop battery not charging
Replace the battery, if laptop works fine from charger without battery installed that proves battery is at fault.
Dec 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hi! I have no sound from my laptop toshiba A100-483 even windows sound doesn't work.thanks for ur help
Make sure Sound Drivers are properly installed...
If you are not geting even windows sounds..
in most of cases Device drivers are not properly installed.
regards,
Dec 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
