Question about Acer AL1916W 19" LCD Monitor
The monitor on shows black screen only
I need a compatible Transistor NPN 40T03GP
  • 1,684 Answers
Hello
We sell a full parts kit that comes with both 40T03GPs and the pico fuse that needs to be replaced and the 2 capacitors, the kit runs $16.00 and free shipping. If you want to purchase one go to:
www.ccl-la.com/LCDrepair1.htm , that link also has the repair guide showing where the fuse and caps need to be replaced.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 15, 2009
Amplifier. has transistor h649a which is the equivalent for that transistor
The H649A is the 2SB649A made by Huashan.
The datasheet for the 2SB649A is here:
http://pdf.datasheetcatalog.com/datasheet/HitachiSemiconductor/mXwuwqt.pdf
The matching NPN transistor is the 2SD669A (or H669A).
May 16, 2014 | Car Audio & Video
I want transistor Q103 value smps please
The service manual doesnt show what the transistor type is. It's an npn high voltage low power switching transistor. does it have anything printed on the body ie Cxxxx where xxxx are 4 numbers
Jul 01, 2011 | Hitachi CP-RS55 LCD Projector
Help me please! I need replace transistor d3402(drive flyback televisor) but don´t find it. thanks
SONY TRANSISTOR TO-3 NPN 140V 12A 100W
Almost anything will go in there.
TV Flyback transistors are usually BU208 or BU208D if a diode is used. They are Very high Vceo
not as you describe a 2SD3402
Jan 22, 2011 | Computers & Internet
I had a akira tv remote but it could not work,,, and then the transistor poart is missing?
hi,
u can use the C945 NPN (emitter,collector, base configuration ) transistor in that place.
ok
Dec 27, 2010 | Akira SV-4201 42 in. Plasma Television
Equivalent of transistor c5929
2SC5929 - Si, NPN, diffused CRT Horizontal Deflection Output Transistor.
Producent - Matsushita/Panasonic
(Absolute Maximum Ratings)
IB=5,5A
Ic=12A
Icpeak=22A
VCB0=1550V
VCE0=600V
Ptot=50W
similiar tx; C5931, C5129, C5587, C5909
Aug 05, 2010 | Computers & Internet
What transistor would be the replacement for the small transistor in my alpine mpr-m1000 called D600k Y 834? Where could I get it and what would it be called?
The transistor is LIKELY a 2SD600 which google brings up data sheets for you.
It is an Epitaxial NPN 100/120 volt 1 amp transistor, but do check the datasheet for verification.
A lot of these units seem to drop the 2S prefix of the Japanese labels.
Trace a lttle of the circuit and verify the 2SD600 makes sense.
Mar 27, 2010 | Car Audio & Video
Same...
In a CRT type monitor/TV the push-pull transistors are used in the vertical output section to provide both poistive and negitive signal amplification. By using a NPN and PNP transistor set you can amplifiy a signal that goes positive and negitive. A NPN uses the positive portion of the input signal and then amplifies that signal (pushing it to a higher positive signal level)(PUSH). The negative portion of that same signal to sent to a PNP transistor to amplify the negative to a more negative value PULLing the signal lower/more negative). The out puts of both transistors are combined providing a PUSH-PULL transistor set.
Now days the use a chip with all the transistors and a lot of the associated components inside. The LCD I worked on used FET's N-type and P-type (negative and positive).
I hope this helps.
Jun 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
702 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
