Question about Whirlpool Washing Machines
Agitator on Estate washer will not fully agitate.
  • 52 Answers
Replace the dogs on the agitator.
Posted on Jul 15, 2009
Tip
How to fix the agitator on your washer
for kenmore,whirlpool,roper,kitchenaid,estate,inglis,if your agitator will not agitate,remove agitator cap,use a 7/16 socket to remove the bolt,pull top half of agitator out,you will see 4 little gears called dogs,remove them from the agitator,replace with new ones,put everthing back together,your done,you can get parts at your local,appliance parts store-mike
on Jan 31, 2010 | Washing Machines
HOW DO I SEPERATE THE TOP PART OF AGITATOR FROM THE BOTTOM PART
Remove top cap and inside of agitator you will find 7/16 bolt i believe..maybe 3/8 either way,..remove bolt and pull agitator up and out of washer..I put the agitator on floor and hold bottom with my feet and pull up on top portion...i do this to replace the agitator dogs
Jan 22, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Agitator not working properly...lower part works while the upper part just sits there not turning
you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
Dec 31, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate by whirlpool/agitator will not turn
under the top half of the agitator there are 4 agitator dogs. these pieces have edges to them that catch the inside of the upper agitator and if they are worn down, and they do wear, it will not move the agitator for you. hope this helps.
Oct 14, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
The dogs are broke on the agitator. Need a new set of dogs.......(duh ...not the barking kind, it's part of the agitator) Agitator has two pieces. It is the top piece.
Jul 14, 2009 | Estate ETW4400VQ Top Load Washer
How can one remove the agitator,it seems to move slower than it used to
If this a Whirpool manufactured washer (this includes Kenmore, Estate and Roper), the agitator can be removed by following these steps:
1, Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Some washers will have a fabric softener dispenser on the center post.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
If you have questions, or need additional assistance, please let me know.
NOTE: When reinstalling the agitator make sure you do not over-tigthen the bolt. This can damage the agitator and restrict its movement. Tighten until snug.
Jul 08, 2009 | Whirlpool WTW5500ST Top-Load Washer
How to replace agitator dogs
Remove the bolt and pull the entire agitator off. Turn upside down and separate the two pieces. You'll see the part that holds the dogs in place
Jan 04, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
