Question about Sport & Outdoor - Others
The handles on our Sportsstuff Afterburner are breaking. Where can I purchase a new covering for my Afterburner (4 ft. dia.)? Nevin L.
Replace dooor handle side by side kenmore coldspot 10656833602
There is a cover on the handle. Remove with a screwdriver by gently prying...careful not to break the plastic clips. Once removed, unscrew the main handle & replace.
Dec 17, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
The power on my tv keeps going on and off how can i fix it
Many Samsung LCD panels have a main 'power supply' circuit board, which relies on Capacitors.
If you're technically inclined, take the back off and inspect the cluster of capacitors near the power supply. If any of the capacitors look out of shape, too fat, or burnt at the solder joints, then you've found the fault.
From memory, the most common capacitor to fail, is the large 1000 uF one.
Good luck !
Scott
Jan 27, 2013 | Samsung Televison & Video
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
I need an exploded view of a 1994 toyota 4 X 4 hub
Exploded view of the free wheeling hub
Turn the handle with your hand to the free position
Note the directions in which you can turn the handle: left-free, right-lock
  1. Remove the hub cover. Set the control handle to free.
With the handle in the free position, remove the six hub cover bolts
  1. Remove the cover mounting bolts, then pull off the cover. Remove and discard the gasket.
Pull the cover off
  1. Remove the bolt with washer.
Using the correct size wrench, loosen ...
... then remove the center bolt and washer
  1. Remove the mounting nuts and washers.
Next, remove the outside mounting nuts and washers
  1. Using a brass bar and hammer, tap on the bolt ends, then remove the cone washers.
Using a brass bar and hammer, tap on the bolt ends ...
... then remove the cone washers
  1. Pull off the hub body.
The free wheeling body should come off easily; be sure to discard the old gaskets
  1. Remove and discard the gasket.
To install:
  1. Place a new gasket into position on the front axle hub. Install the free wheeling hub body with the cones washers and nuts. Tighten the nuts to 23 ft. lbs. (31 Nm).
  2. Install the bolt with washer, tighten to 13 ft. lbs. (18 Nm).
  3. Apply multi-purpose grease to the inner hub splines.
  4. Set the control handle and clutch to the free position.
  5. Place a new gasket into position on the cover.
  6. Install the cover to the body with the follower pawl tabs aligned with the non toothed portions of the body.
  8. i hope this is what you are looking for
  9. plz vote comment and reply if need more help
Jan 18, 2011 | 1994 Toyota Pickup
Spacks on 15" orion 2 xtreme sub
Here are the Specs from Orion's spec sheet.
Sensitivity @ 2.84V/1m 93DB
FS 23Hz
QMS 9.05
QES 0.47
Qts 0.44
BL (Force Factor) 8.7 TM
SD (Piston Area) 500 sq.CM \ 78 sq. in.
VAS (Volume Acoustic suspension) 224 Liters \ 7.92cu.ft
Xmax 7.75MM \ 0.30 in.
Enclosure Recommendations
Sealed Volume 1.60 cu. ft.
Vented Volume 2.75 cu. ft.
Port Dia (Inside Dia.) 4 in.
Port Length 8.5 in.
Nov 07, 2009 | Orion Xtreme XTR15d Car Speaker
Same as others plastic door handle mounts broke
This as you know is not an isolated incident with this happening. There are dozens w2ho have had the same experience. Contact your obudsmen in writing about this as it should be covered under Manufacturers warranty. It is a known problem on this item and is not a problem caused by its use or by accident of the purchaseer. It is a faulty item used in m,anufacturere and therefor is covered by a warranty. Put your complaint To the President of SAMSUNG at their Head Office not their support contact. State your experience with the handle, the staff at support and procide the copy of the letter to your Ombudsmen as well as an intention to attempt a class action fro others who have this problem.
Please rate our help++++Thanks for using FIXYA
Sep 28, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
Installing a bushing I have a snow blower with as 1 inch keyed shaft. I have purchased the same make of replacement engine. The problem is that the new engine has a 3/4 in shaft with a key way. How do I...
If you bought the engine new from a dealer, ask about the availability of one with the correct shaft size or a crankshaft with a 1" PTO journal that you could install in the new engine.
The manufacturer designed the machine with the 1" PTO shaft for safety reasons. The load put on it during operation may be too much for the 3/4" shaft and cause it to break while running which could KILL some one!
You would have to replace the pulley, there is no SAFE way to use a 1 inch ID pulley on a 3/4 OD shaft, and if I am not mistaken, the keyway in the new engine is 3/16". and even if is 1/4, there isn't a "taller" 1/4" square key.
Just some things to think about! Chuck
Sep 21, 2009 | Garden
I am looking onto getting two Lightning Audio S3.15.VC2 subwoofers but I would like to know all of the speaker's parameters before I buy them.I have already looked at the manufacture's website and they...
S3 series is better suited for small sealed enclosures.
The S4 should be close to what you're looking for
T/S for the S4 (use the last number in each line):
Model - Strike S4.10.VC2 S4.12.VC2 S4.15.VC2
Nominal Impedance (Ohms) Dual 4 Dual 4 Dual 4
Voice Coil Diameter - (in.) 3 3 3
FS (Hz) 26.7 25.5 21.9
QTS 0.28 0.29 0.35
VAS (cu.ft.) 0.89 2.43 4.81
VAS (liter) 25.1 68.9 136.3
Xmax (in.) 0.64 0.64 0.64
Xmax (mm) 16 16 16
SPL (dB M/W) 85.2 85.7 87.6
Power Handling (RMS) 500 500 500
Power Handling (Max) 1500 1500 1500
Mounting Dia. (in.) 9-1/2 11-3/8 14-1/8
Mounting Dia. (mm) 241 289 359
Mounting Depth (in.) 5-1/2 6-1/16 7-1/8
Mounting Depth (mm) 139.7 154 181
Speaker Dis. (cu. ft.) 0.15 0.20 0.25
Speaker Dis. (liters) 4.3 5.7 7.1
Total Sealed Box Vol. (cu. ft.) 0.65 0.75 1.25
Total Sealed Box Vol. (liters) 18.4 21.2 35.4
Total Vented Box Vol. (cu. ft.) 1.75 3.0 3.25
Total Vented Box Vol. (liters) 49.6 84.9 92.0
Otherwise - call their customer service line @ (888) 881-8186
Thanks for using FixYa - A good rating for your FREE answer is appreciated.
Jul 04, 2009 | Rockford Fosgate Car Audio & Video
Oh and what do i
TORQUE VALUE CHART
7/16" dia. 50 to 60 lb-ft
12mm dia. 70 to 80 lb-ft
1/2" dia. 80 to 90 lb-ft
5/8" dia. 110 to 125 lb-ft
*Use this chart to get correct torque values for each size wheel stud. I hope this helps and don't forget to rate my answer.
Feb 01, 2009 | 2002 Chevrolet Malibu
From what is an Inflatable Towable made of?
AN INFLATABLE WATER TUBE IS GENERALLY CONSTRUCTED FROM AN ENCLOSED FLEXIBLE PVC RUBBER BLADDER AND SURROUNDED BY A NYLON FABRIC COVER. MOST TUBES CONTAIN A VALVE THAT ALLOWS THE RIDER TO INFLATE THE TUBE MANUALLY OR BY WAY OF AN AIR PUMP. RIDERS SHOULD LOOK FOR TUBES THAT HAVE ENOUGH HANDLES TO ALLOW THE RIDERS TO SAFELY AND COMFORTABLEY RIDE.
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Sport & Outdoor - Others Logo
37 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
