Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Filter Basket pops open while grinding and brewing
As my coffee maker is grinding or brewing, the filter basket pops open, to spray coffee and grounds everywhere.
Clean all the moving parts with a kitchen grade cleaner and then flush with water and air. The mechanism gets gummed up with coffee and gooey liquid over time.
Posted on Feb 05, 2010
Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
Posted on Jul 21, 2009
I just removed the filter assembly took out the spring reinstalled the filter assembly now the door has no outward pressure to force the door open. To open the filter door just push the button and pull out from filter door bottom.
Posted on Nov 10, 2013
DGB-550BK Filter basket won't stay shut when either brewing ground coffee or grinding beans.. With the ground; the basket pops open mid brew and makes a mess everywhere. When grinding beans, I've noticed...
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Jan 19, 2010 | Cuisinart DGB-550BK
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Aug 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Sometimes coffee maker overflows
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
May 21, 2009 | Bunn NHB Coffee Maker
Cuisinart Grind & Brew DGB-600 fills up water in goldtone filter;
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter basket opening during brewing
Push the permanent filter's basket handle all the way down and then reclose the filter basket drawer lid. There is a pretty flimsy piece of plastic holding it in, though - may require replacement.
Sep 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Filter basket pops open after grinding GROUNDS AND WATER EVERYWHERE!!!!
I had that problem a few times. When the door is open and the basket is removed I pushed in and held the release button while I cleaned that little hook area that holds the pop out tray in place. I just used a paper towel and nicely warm water. Works fine afterwords. I try to clean this at least every week.
Jan 27, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
972 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
