Question about Polaris Pb4 - 60 Booster Pump
Pump seems to running but the water pressure going to polaris does not change when you turn Pump on or off. Polaris is not performing as usual. Is there a way to check if pump is actually pumping the water?
Solution #1 worked. Thanks!!!
Posted on Apr 08, 2010
  • 128 Answers
Disconnect the hose from the wall and with your hand fell how much pressure you have. It's possible you have an air lock. With the hose off the top fitting of the booster pump and the hose pointing away from you and electrical turn pump on and see what kind of pressure. This will also clear the air.
Posted on Aug 23, 2009
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
Pump seems to start ok - 240 volts - shaft spins but not enough water pressure to move the polaris cleaner?
It sounds like you could have some debris stuck in the impeller on this pump. This is a common problem and anything that gets past the pool filter can end up stuck in this pump.
Sep 03, 2011 | Polaris Pb4 - 60 Booster Pump
The wheels are not moving when hooked up, When i move one manually they all move. i made sure the pool filter basket is clean and the water pressure going into polaris seems like it is strong.
Also check the skimmer basket and pump. Make sure they are functioning properly. Check all hoses, connections, and swivels for leaks that could be causing a lack of water pressure in these pool cleaners. Make sure that your wheel RPM is between 28 and 32. Increase the pressure to create more RPM.
Aug 29, 2010 | Polaris 380 In Ground Pool Cleaner
The pump seems to be running but the water is not coming through with any increased pressure, therefore the cleaner is not being propelled within the pool. What could cause the pump to suddenly lose...
You have spun the center out of the impeller. Get a new impelleer at your pool supply place. While you have the pump open, replace the seals as well.
Jul 20, 2010 | Polaris Pb4 - 60 Booster Pump
Will the the pump run if it is connected
You can not connect the pump to run 'backwards' since the motor rotation is an internal connection you cannot change. Yes, the port should have water pressure, not a vacuum. Perhaps the wall inlet adapter is installed into the wrong wall port? Did someone change the wall port to allow for a suction side cleaner? Is this a new installation or sudden problem with an old one?
May 15, 2010 | Polaris Pb4 - 60 Booster Pump
My no flow light is on and the polaris won't move
Not too much to go on but i'll give it a shot. Polaris won't move cause there is no or little water pressure. A number of things can cause this, and i'll give you the most common. Dirty or clogged filter. If it's a cartridge type, remove cartridge and try running without it. Clogged output of pump. No input to pump. Make sure pump is primed.
Mar 22, 2010 | Polaris 380 In Ground Pool Cleaner
Polaris Pb4 - 60 Booster Pump Logo
338 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
