Question about Dell Photo 964 All-In-One InkJet Printer
Dell 964 all in one won't scan or fax director from Office 2007
I have downloaded all the recommended drivers to run with Vista but there is just no software it seems to get the scan from the printer to the computer whether to clipboard/email or file. Likewise if I do a letter in word and want to fax I used to press print with old system and choose Dell 964 fax and it would send direct from computer. Dell want £38 to tell me the answer and I have a feeling all they are going to tell me is it's not compatible as I have seen that mentioned when I google.
  • 3 more comments
  • needles17 Jul 14, 2009
    A USB Cable
    When I go into Scanners and Cameras it does say Dell 964 but when I try to search for Scan nothing like Windows fax and scan comes up.
    I just clicked on the 964 icon in scanners and cameras and it tested the scanner - said it was ok - but the printer did absolutely nothing!!
    Am I right with my suspicion that the scanner and fax won't work anymore then do you think? As I am in Jersey in the Channel Islands its now time for sleeping so will see answer tomorrow.
  • needles17 Jul 15, 2009
    Yes that works but it's not a good scan from there is it? So there is nothing wrong with the printer itself then its just that Vista won't allow its software to work?! Is there no way round getting the original software of the disc which came with the printer to work on Vista - I would have thought Dell would have told me that Vista wouldn't work with their own printer - I spoke to the Sales guy about my printer because I ordered some cartridges at the same time.!!
  • 198 Answers
I've searched a few places I can think of that may resolve and help this tricky issue.
The best I could find was the Driver for Vista.
Let's try it this way:
  1. Unplug the printer from the computer.
  2. Run "Start", select "Control Panel" select "Add/Remove Programs". Look for your AIO on the list and select "Remove".
  3. Go back to "Control Panel", click on "Printers & Faxes" Select your AIO and hit "Delete"
  4. Now go to "Toolbar", then "File", then "Server Properties", select the "Drivers" tab. Select and delete each AIO driver you see.
  5. Reboot the computer. Leave AIO unplugged still.
  6. Run the driver you downloaded. When it asks you to plug the AIO in, go ahead.
  7. Reboot the computer.
This should help, but knowing Dell, you may need to do steps 1 to 5 THEN download the driver, as Dell would probably try to auto-install...
If this doesn't work, then yes, it's Vista. Why Dell would charge you $70.00 for answers is beyond me.
Good luck! Let me know if this helps.
Posted on Jul 15, 2009
Hi there
Please let me know how the printer connects to the computer. Is it via a USB or a network cable?
Thanks.
Posted on Jul 14, 2009
  • Anonymous Jul 14, 2009
    Thanks.
    If you turn on the printer, then head over to Start > Control Panel > Scanners and Cameras (you may have to look for this in the Control Panel, possibly under Hardware), do you see your scanner in the list? Please let me know.
    Also, head over to Start, type in Scan (in the Start Search box in the Start menu), and click on Windows Fax and Scan (if this doesn't come up it's not supported by your Vista edition).
    If it does come up, open up Windows Fax and Scan, go to the Scan option in the left side pane, and try doing a scan from there. Does it work?
    Let me know how it goes.
    Thank you for performing the tests mentioned.
    As it is listed in Scanners and Cameras, this would mean it should work through some sort of software.
    One software which you can test the scanner with is Paint. Simple go to Start > All Programs > Accessories > Paint.
    When Paint opens, go to File, and look for something like Acquire from scanner, or Acquire, or Use scanner or similar. Basically there should be an option in Paint's File menu which allows you to get a scan from the scanner.
    Once you find it, give it a go, and see if it tries to scan.
    Thanks
    nLinked
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
Is my old Lexmark x5470 compatible with MS Office Professional 2007?
MS Office is only bundled set of Office applications software eg. Winword, Excel, etc.......It had nothing to do with the compatibility isuses with any devices like printers, fax or scanmner, etc....
Compatibility isuses are with the Operating Systems (OS) eg.XP,Vista, Win 7 ... on your PCs. Different OS require different versions of Devices "Drivers & software" . If you can successfully install your device Drivers & software for the AIO "Lexmark x5470" on your PC Operating System, you should be able to print, scan or fax from MS Office applications.
Hope it helps.
Jun 13, 2011 | Microsoft Office Professional 2007 Full...
How do I install a dell 964 printer without the cd
Windows XP Driver : ftp://ftp.us.dell.com/printer/R113115.EXE
Widows Vista Driver : ftp://ftp.us.dell.com/printer/R146717.exe
Select the one approriate for your Operating System. Download and run the Setup file with the Printer connected and powered on.
BD
Sep 06, 2010 | Dell Photo 964 All-In-One InkJet Printer
Dell 946 printer wont scan on windows vista
This is your driver causing the problem. If the download was for several printers you can try to reinstall the driver manually for your specific printer. If the driver was supposed to be for your specific printer then dell has put out a bad driver which they do sometimes. You can try alerting them through their forums,their customer support, or call them and once they know they have a problem, they're usually pretty quick to fix it.I would try uninstalling and reinstalling the driver first though sometimes they don't install right if the computer is under a heavy load.
Jun 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 scanner isn't working with Windows Vista 64-bit
Hi , I can help installing the driver and fixing the printer issue for you , I can take remote access of your system and fix issue for you, one time charges USD 25; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Jun 20, 2017 | Dell Photo 964 All-In-One InkJet Printer
Can my HP Photosmart C4380 support Microsoft Office Professional 2007 Fax and Scan? Or must the HP fax and scan only be used?
Sorry, Fax and Scan is part of Windows Vista not MS Office. I have been advised by PC World team that this printer (HP Photosmart C4380) does not have the necessary drivers to support Vista Fax and Scan wirelessly and can only operate with the HP Fax and Scan which is very basic and only seems to function via USB cable, not wirelessly. Update drivers may become available.
Jul 04, 2008 | HP Office Equipment & Supplies
Dell 964 scanner
First do your scan on Dell 964 scanner &printer. Scan to clipborad. You hear it scan but nothing happens on your computer. Go to control panel - scanners and cameras - scan profiles - find the document you have scanned, select it and click edit - click preview - in the left corner you will see in blue "How to scan a picture" click that, it will lead you to Windows Photo Gallery - there click on file and import from scanner of camera - it will scan there and your scanned pics will be in your picture folder :) Took me a while to figure it out :)
You can avoid all this and go directly to Windows Photo Gallery :)
May 26, 2008 | Dell Photo 964 All-In-One InkJet Printer
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
105 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
