Question about GE Spacemaker JVM1640SJ Microwave Oven
I have ge under cabinet microwave model jvm1331 004 that i need to remove. what holds the unit in place?
  • 520 Answers
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Posted on Jul 14, 2009
Need to know how to take down this under cabinet model for replacement?
Two or three screws on the top of this microwave (mc), which are located on the top cabinet. Loose them first. Also the bottom of the mc is attached to a metal edge against the wall. Need at least two men to hold and unload it from the wall.
Sep 27, 2015 | GE Microwave Ovens
How do you safely remove a ge spacemaker microwave oven from its wall mount?
This is a two person job. You have to have one person holding it and the other takes the screws out from the cabinets above the unit. There should be two screws that are inside the cabinet that hold it up against the bottom of the cabinets. When those are loose you can slide the unit forward on the rails that attach to a large wall bracket. Or some use a lift type latch to the wall bracket.
Apr 26, 2015 | GE SpaceMaker Microwave Ovens
How do you uninstall a GE spacesaver microwave oven
Deanna, it would probably be best to have a second person there to help hold the microwave. You would need to loosen and remove the screws from inside the cabinet that hold the microwave to the cabinet. Just to let you know, as you face the microwave, the right side of it will be a lot heavier than the left side because of all the equipment that is behind the control panel. You might put a pillow or something else soft to help cushion the microwave and protect your counter in case it lets go all of a sudden. Depending on the model and the type of mounting bracket there could be anywhere from 3 to 6 screws that hold it in place. Hope tis helps!
Feb 13, 2015 | GE Microwave Ovens
How do I remove a GE spacemaker model jvm130k
I assume that it's mounted below a cabinet on the mounts supplied with the microwave. If that's the case, there are four buttons on the top of the microwave in each corner. They fit into holes in the mount then slide into depressions which hold the unit in place under the cabinet.
To release the microwave push up from the bottom then try sliding it backward first. If you are able to move it, carefully slide the whole unit until it drops through the holes and is clear of the mounts.
Be very careful because the unit is pretty heavy and you'll get its full weight when it drops through the holes.
If it doesn't move when you try to slide it rearward, try sliding it sideways in either direction. The direction you must slide it in is determined by how the mounts were installed but it should slide out fairly easily once you know which way to move it.
Dec 04, 2014 | Microwave Ovens
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Mar 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
873 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
