Question about Pioneer PD-F507 25-Disc CD Changer
Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
Pioneer PD-F505 lower CD door closer spring has sprung loose. Anyone know how to reattach? Also CD's are not getting loaded correctly, the lower white arm does not rise quite enough to get the CD into the "player" mechanism/head. Any ideas? Anyone have a service manual for this unit???
    New Friend:
Wheres the cd port arm?
Posted on Jan 20, 2014
    Problem Solver:
  • 13 Answers
Use krazy glue to get the arm glued with the cd port or use electrical tape.
Posted on Jul 14, 2009
My pioneer pd f505 is lock how can i unlocked it
The loading mechanism is out of alignment and needs to be fixed before the door will operate correctly.
Feb 26, 2013 | Pioneer PD-F505 CD Player
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
I need a manual
Hiya,
Here is the manual:
PD-F505 Manual
You will need to rate this CD player (put stars in 4 star area's) before it lets you download.
I have downloaded the file, it is clean and it is the correct manual for your CD player.
Regards
Mike
Mar 24, 2010 | Pioneer PD-F505 CD Player
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
It hmmmm's
When you said it sitted there.Did you have the screw lock on or not ? It could be the loading belt or the arm lever broken this arm it move from left to right to pick up the disc
However this model require a qualifier Tech trained from Pionner to dismantle or repair. I suggest to bring it to Pionner or 1 of the service center for Pioneer
Cheers
Dec 09, 2008 | Pioneer PD-F505 CD Player
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
Cant play cds 6-25
The short answer is no, but that is not really usefull. If I remember this model correctly, the movement is controlled by a motor/belt assembly. The positioning is read by a photo sensor setup. These mechanisms are known for getting confused. This is not a repair that should be attempted by anyone without prior servicing experience. There are specific dis-assembly/re-assembly sequences to insure proper alignment of the mechanism. Expect a repair cost af around $100 for this with an additional $15 or so if the sensors need to be replaced.
Dan
Apr 01, 2008 | Pioneer PD-F605 CD Player
CD won't deliver into player, from rack.
They tend to break... and the cure is to replace the arm. This involves removing the transport and then splitting it, replacing the load lever, and then refitting transport. Be careful not to break the transport limit switch mounted to the chassis when removing and refitting the transport. Not an easy job for the "non handyman". Take it to a Pioneer agent if you don't feel confident. Good luck. "FixYa" rating would help my profile. Thanks
Jan 16, 2008 | Pioneer PD-F505 CD Player
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
Pioneer PD-F507 25-Disc CD Changer Logo
414 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
