Question about HP LaserJet P4014n Printer
I am getting a grey, dusty looking background on all the printouts... any ideas? We just put a brand new toner cartridge in about a week ago and has been fine until today.
    Scholar:
  • 81 Answers
Is it a genuine toner? Usually this is caused either by a spill, or by the use of refilled toner cartridges. The only really sound test is to get a new, or known good cartridge and test it with that. If its still dirty then the printer needs maintenance/cleaning by an engineer.
Posted on Jul 14, 2009
Printout showing grey print background
Sounds like you are not using genuine Kyocera toner.
Try using new toner can take a few hundred copies to work through the machine.
May 07, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Hp1020 printing grey backgroud
Hello;
The most common reason that laserjet's get grey background print-outs is that the toner cartridge's drum has gone bad. I have seen it many, many times on new and old cartridges and the only way to fix it is to buy a new toner cartridge. Sorry for the bad news.
Good Luck!
Rich Lilja
Oct 27, 2012 | HP LaserJet 4 plus Printer
I just changed the toner cartridge on my hp laserjet 1020 and now the entire background of each print has a very fine gray tone
put the old cartridge back in and run, did the grey background go away? More then likely just a defective toner cartridge you simply need to replace again and if the company you bought it from is reputable they should give you a new one at no more cost to you... If this helps please mark as FixYa! please... Get Paid To
Aug 04, 2011 | HP LaserJet 1020 Printer
WHENEVER I PRINT I GET A GREY BACKGROUND IT LOOKS LIKE DUSTY PAPER BUT IT ISNT? WHY IS THIS?
If the black toner cartridge (Q6000A) is not original, problem with the doctor blade, bad calibrated.
Use Original cartridges?
See This:
The amount of background toner shading becomes unacceptable.
1.The media might not meet HP specifications.
  • Use a different paper with a lighter basis weight.
2. Use a different paper with a lighter basis weight.
  • Check the MFP environment.
3.One or more print cartridges might below. If non-HP print cartridges are used, no messages appear on the control panel or in the HP ToolboxFX.
  • Replace any low print cartridges.
Aug 03, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
I have a Brother MFC-7340 and recently replace the toner and now the background is dirty looking when I print, ie grey where it should be white! What can I do to clean it up? Thanks!!
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
Mar 05, 2011 | Brother MFC-7340 All-In-One Laser Printer
I HAVE TONER ALL OVER PAPER WHEN IT PRINTS OUT
If the toner is loose, and you can smudge it with your fingers, then it is a fuser error. The fuser is the hot roller at the back that melts the toner onto the page. If the toner is not loose but the page just has a kind of grey dusty background which cannot be rubbed off with your finger then the problem could be a dirty transfer roller or a dirty cartridge. It could also be dirt in the optics if it is used in a dusty environment. Cleaning the lenses with a clean dry cloth should clear that up.
Apr 28, 2010 | Brother HL-5240 Laser Printer
No hint of toner shortage but printouts lack color
Can be short of toner before the pagecount is at max for the capacity of cartridge.
If you look at the roller at the edge of the toner cartridge, it should have an even coating of fairly dense toner.
Remove each toner in turn, shake, and reinstall. This will often give you a few more pages.
Rated capacity is a guide based on a 5% page coverage.
Some remanufacturers are a little 'economical' with the toner they put in their catridges.
Jan 20, 2010 | Samsung CLP-510 Laser Printer
Gray background
if you have a laser printer you may need to clean the printer or install a new drum cartridge, if it is ink-jet you will have to clean the bottom of the ink cradle it sound like you getting grey background from a toner/drum cartridge.
good Luck
Let em know if this helps.
Jan 29, 2009 | HP LaserJet 1200 Printer
HP LaserJet P4014n Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
