Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Want to know applications of DMA in real time
How and by what mechanism is DMA used in peripheral device drivers as well as functionalities such as network packet routing, audio playback and streaming video.
  • 118 Answers
Re: want to know applications of DMA in real time
Now a days DMA is replaced with  Bus Mastering technology , but still some sound chips use DMA to increase the Audio performance
DMA is a kind of technology where the data transfer is controlled by a chip other than CPU thus freeing cpu for other tasks.
When you request data from a high speed pheripheral for reading or writing , an Interrupt is generated by the pheripheral to alert the CPU , CPU then service the ISR ( Interrupt service routine) to perform the task , DMA plays its role here , it taks control from CPU for further data transfers over a bus , and act as a second cpu and monitor the data transfers.
Posted on Nov 20, 2007
    An expert who has answered 500 questions.
  • 508 Answers
Good Morning
IT it a little "brige" to some sound aplications or routing signal to Printers or Sound Cards, but not for Network. Not good sometimes for Sound Cards, but you can play sometimes with settings and see what happend, you always can go back the DMA at previuos state, or simple, disable.
Posted on Nov 18, 2007
0 characters
3 Points
Am looking for sound drivers for dell 520
You can get sound driver into dell website, friend. Just visit their website and look for download drivers...find the model of the driver...choose what kind of operating system you make the system driver compatible...then DONE
Sep 21, 2011 | Dell OptiPlex GX520 PC Desktop
If your older PC has lost some zip -- An easy thing to check & fix.
After a while, usually several years, your hard disks wear. As this happens the disks will have errors. Windows keeps track of these errors and if they grow too numerous Widows will take actions designed to reduce the possibility of a catastrophic event. One thing it will do is change the method it uses to access the hard disk. It will change from DMA mode to PIO mode and slow you way down. This tip will restore DMA mode so you can get a little more use out of your aging system. You won't need any disks or special software, but you will have to reboot twice.
In Windows get to Device Manager.
One way to get there is click Start, right click My Computer, select Properties, click Hardware tab, click Device Manager button.
In Device Manager, press the + next to IDE ATA/ATAPI controllers.
It should look something like this:
Double click Primary IDE Channel. Click the Advanced Settings tab. If there is no Advanced Settings tab then this tip will not help you, but check the other possibilities (Secondary IDE Channel, other controllers) the same way.
Check to see if the Current Transfer Mode says PIO. PIO stands for Programmed Input Output. It is the slowest mode of disk access. If the Current Transfer Mode is something with DMA (Direct Memory Access), then this tip will not help you as this is the preferred mode.
Check to see if the DMA if available is selected in the Transfer Mode box. If not, select it.
At this point you have determined that you are using PIO mode for one or some of the IDE Controllers and that you have selected DMA in the Transfer Mode. The next thing is to make Windows load the correct DMA driver.
Click the Driver tab.
Click the Uninstall button. Click the OK button. Do this for all IDE Controllers that show PIO mode.
Windows will ask if you want to reboot. Let it happen. Windows will reboot, load the DMA drivers, and tell you it has to reboot again. Let it happen.
Now the DMA drivers should have been installed and some of the snap should return to your PC.
Eventually, Windows will revert back to PIO mode. Your disk is wearing out. Get a new one!
on Sep 21, 2010 | PC Desktops
What are drivers?
Drivers are small software programs that help control devices attached to your computer because drivers enable your operating system and other software to communicate with various hardware devices, controllers, and other peripherals. In other words, drivers work as instruction manuals that provide software with the information with regard to controlling and communicating with different hardware devices.
Why do we need drivers? Drivers help computers identify and run installed hardware. A device driver is a code that an operating system uses to control disk devices, display adapters, input devices such as a mouse or trackball, modems, fax machines, printers, and other hardware. Without drivers, computers will not be able to distinguish between a sound card and a modem. Most computer devices and peripherals need drivers to run, which means that computer accessories, such as printers, scanners and digital cameras also need drivers to function. This is what all computer hardware and accessories that are purchased come with drivers stored in either a floppy disk or a CD. A computer automatically loads the drivers when these disks are inserted in their respective drives.
Like any other software, drivers are upgraded and updated by the manufacturers to remove bugs, add extra functionality to the hardware or to improve the performance of the device. Unless you update your drivers regularly you may face problems ranging from the relatively minor, such as having hardware that seems to perform poorly, to the more major problems such as hardware failure, hardware conflicts and complete system crashes.
Choosing and installing the correct device drivers for a given hardware is often a key component of computer system configuration.
Where you can get Drivers? Drivers can also be downloaded from the websites of hardware manufacturers. You can download the most recent or updated drivers for your hardware. You can do this by navigating through each manufacturer’s website and searching for the page that allows you to download drivers for their products. However, there are some software (ex. Driver Robot) that automatically scans your computer, looks for the drivers you need, and automatically installs them to your computer. These kinds of software are very easy to use and they can ensure that you will have the most up-to-date drivers for your devices.
on Apr 08, 2010 | PC Desktops
How to use fingerprint,scaaner and fargo print with terminal of pc,if not support add detial.thank
Simply install the driver for the scanner and printer on the HOST system. Plug in your peripherals and when the user on the L300 logs in they should see the printer. The problem with the fingerprint scanner is depending on the make/model, it may not work with the NComputing device. The only way it will have a chance of working is to make sure the device has a live session, sitting at a logon prompt for the desktop. The L300 by itself won't know what to do with the fingerprint scanner. It needs a session to the host to marry up the driver with the peripheral. Also make sure you have the latest vSpace software as NComputing has implemented a new USB architecture for larger USB peripheral support.
Dec 06, 2010 | NComputing L300 Terminal Computer PC...
Computer Repair Services
Computer repair includes software and hardware repair. Hardware repair is needed when any part of the computer is not functioning as expected. Software repair is required when any software program is not executing properly.
Need of computer repair
Computer repair is needed for making your computer function properly. Your computer will function properly if all its parts are working properly. Some of the issues for which you require computer repair are as follows:
• Computer automatically shuts down
• Computer takes much time in launching applications
• Computer system crashes or locks up
• Blue screen error
• Computer makes beeping sound when switched on
The reason for most of the computer issues is the lack of maintenance. For maintaining your computer and optimizing its performance, you have to update software regularly, clean registry, empty cache files and many others.
In case, you have the knowledge about how to repair your computer, you can perform it yourself. But if you do not have any knowledge in this field, then you can contact a computer support technician.
Computer repair technician is a person who will repair your computer either through online or on-site. Online computer repair is preferred in case your computer needs software repair. If you want to go for online computer repair, all you need to have is an Internet connection. Online computer repair saves your from the pain of taking your computer to some technical services center or inviting some technician at your own residence.
These days most of the companies offering online computer repair adopt the method of remote desktop connection. Technician will access your computer with the use of software made for remote desktop connection. But you have to give him permission for doing so. After getting permission, he will diagnose your problem and after that resolve it. Technician will install, reinstall or uninstall any software, or modify some of the settings for resolving issues.
In case of hardware repair, you have to call a technician in your premises. Technician will diagnose all of your peripheral devices, in case of any faulty one, he will replace that one. He will also update drivers of peripheral devices.
So, it can be said that computer repair is required when your computer is not functioning as expected.
on Feb 04, 2010 | PC Desktops
What is peripheral device? and 2 eg. of peripheral in a computer system
Peripheral devise are the computer devices that are connected to the computer externally such as printer, scanner, keyboard, mouse, tape device, microphone and external modem. They can be internal such as CD-ROM or internal modem and external as the scanner, printer and Zip drive. Peripheral devices can be classified according to their functions.
1. Input
Input devices are the type of the computer devices that are used to provide the control signals to the computer. Keyboard and the Mouse are the examples of the input devices.
2. Output
Output devices are the devices that are used to display the results. Printer, scanner, speaker and the monitor are the examples of the output devices.
A storage device is a device that is used to store the information such as hard disk drive, flash drive, floppy disk and the tape drive.
Hope this will be helpful to you.
Oct 09, 2010 | PC Desktops
Irq dma err
IRQ's (Interrupt Request) LinesIRQ's are hotlines to the main computer (CPU) that allow devices connected to the computer to signal the CPU that they need immediate attention. If you're a Batman fan, think of IRQ's as the Batphone - getting his attention immediately.
Not all devices require IRQ lines, which is good news because in modern (post IBM XT) computers, we only have 16 of them. Of those, 3 are already dedicated to the main system board itself - the system timer, keyboard, and memory parity error signal. That leaves only 13 for all the other devices connected to your computer. This is why IRQ conflicts are probably the #1 problem faced by computer users when they add hardware to their computer.
Its a general rule for ISA-type systems (the standard computer architecture used in most IBM compatible systems) that IRQ lines CANNOT by shared with multiple devices except under special circumstances. For this reason, a good understanding of what IRQ's are assigned to what devices is essential in avoiding conflicts. The table below is a general outline for standard IRQ assignments.IRQ DEVICE USED in AT, 386, 486, and Pentium Computers
0 System Timer
1 Keyboard Controller
2 Tied to IRQs 8-15
3 COM 2
4 COM 1
5 LPT2 or Sound Card
6 Floppy Diskette Controller
7 LPT 1
8 Real Time Clock
9 Substitutes for IRQ 2
10 Not Assigned
11 Not Assigned
12 PS/2 Mouse Port
13 NPU (Numerical Processing Unit)
14 Primary Hard Disk Controller
15 Secondary Hard Disk Controller
Depending on the computer's configuration, add-in devices such as SCSI controllers, sound cards, modems, cd-roms, etc. will want an IRQ line that is already used by another device, and thus we have what is commonly referred to as an IRQ Conflict.
The most common IRQ conflicts seem to be between two COM ports, generally a mouse and modem conflict that ends up freezing the mouse whenever the modem is activated. The table below explains each IRQ and the most common devices each may use.
Oct 18, 2008 | PC Desktops
Compaq D510 sff Dma problem
Those might have been your specs but if you have updated windows some of your drivers autamatically change. Try rolling back the drivers or updating them again. The drivers change frequently when windows hot fixes are dowenn loaded your setting that you had and are trying to set it at are the ones when the system was new.
Dec 17, 2007 | Compaq Business d530 (PB185US) PC Desktop
Audio and video track are not in sync
I guess that your CDROM Device doesn't have DMA (Direct Memory Access) enabled.
From the Microsoft Knowledge Base Article:
To enable DMA mode using the Device Manager
Open Device Manager.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
Change the selection from "DMA if available" to PIO only, and click OK.
Then repeat the steps above to change the selection to DMA if Available.
Oct 14, 2007 | PC Desktops
PC Desktops Logo
154 people viewed this question
Top Linare PC Desktops Experts
Carlos L. Burgos
Carlos L. Burgos
Lars Olsson
Lars Olsson
Are you a Linare PC Desktop Expert? Answer questions, earn points and help others
