Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Bass rattling on Bose Companion 2
I bought these speakers around a year ago, and only in the past week have I had problems. On select songs, the bass will tend to rattle in a manner which suggests it is blown. But for most other songs, there is nothing to indicate that there is a problem.
My Companion 2 speakers were having the same problem with the rattling on certain frequencies and I am happy to say that Steve Allison was correct in my case. The speakers don't handle surround settings very well so if you're running your speakers through a source that had that setting turned on the easiest way to stop the rattling is to just turn the surround setting off. The speakers weren't really made to handle that kind of a signal.
Posted on Jun 26, 2016
  • Brandon Kling
    Brandon Kling Jun 26, 2016
5 Suggested Answers
jazzyboy11
  • 728 Answers
SOURCE: Bose Companion 5 Producing Unstable Sound
The intensive bass is making the speaker shake very much and that could have caused a short that changes the volume after a while when the speaker has been shaking for a period of time. You could try lowering the bass or volume to see if it makes a change in how long it takes to make the volume change.
Posted on Oct 22, 2008
Benimur
  • 6966 Answers
SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 27, 2008
freetek
  • 5568 Answers
SOURCE: I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Posted on Dec 14, 2009
  • 979 Answers
SOURCE: Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
Posted on May 06, 2010
How to open the bass speaker box on a Bose Companion 3 system?
Using a knige or razor blade, lift the edge of the rear sticker up. Do this evenly and you will fnd all the screws that hold it together. Take your time and you can put the sticker back down.
Nov 29, 2010 | Bose Companion 3 Computer Speakers
May 06, 2010 | Bose Companion 3 Computer Speakers
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Oct 18, 2008 | Audio Players & Recorders
Bose companion 5 problems
Have had Bose companion 5s for about three years. The external volume deveice in not active. If I unplug it, the sound goes dead. The indicator light is stuck on green and is very dim.. The touch feature does not respond nor does the volume. Sound is set very low an barely audible. Can I get replacement external volume control or is the problem inside the base unit itself? Any help out there with a similar problem.
Thanks JT
Apr 10, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
418 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
