Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59, Convergence is out, not even on set up menu, and also the picture is bowing. how much to fix or just use it for target practice
  • RCA Master
  • 8,617 Answers
You can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 15, 2009
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have a RCA R56WH78YX53 tv that made a pop or click noise and now the picture is bowed and the colors look like you need 3D glasses. I tried to do a convergence but the tv went blank and now it will not...
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Feb 27, 2010 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52549. I love this TV, but
Try adjusting the convergence in the customer menu. If you can't adjust the colors then you may need to have convergence amplifiers. A professional can do this. Check around for price.
Apr 08, 2009 | RCA HD52W59 HDTV Projection Television
Picture is blurred and bowed
ok you have a convergence problem. first check out the article the fl231 problem in the tips and tricks section it will tell you of a condition that might mean an easy repair. first check to see if you have the convergence options in the customer setup menu
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Top and bottom of picture is bowed.Images are doubled and letters
one more question , could or can you access the convergence menu ?
the fuse will be next to the flyback transformer ( high voltage ) and ill look tan in color( 3 of them )
also the flyback pins have to be resoldered also
Feb 03, 2009 | RCA HD52W59 HDTV Projection Television
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Convergence
oki this is an itc 222 or rca hd 52.... if your convergence option is not availvble in your menu and you have a bowed multicolored 3 d ish picture then this points to a special fuse fl231 if you can get this fuse and can solder then it should cost you about 5 bucks and 30 minutes to fix...ill give you more intstruction on how to do this repair. whats your model of your tv]
May 23, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
429 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
