Question about Canon DV-MV830i Mini DV Digital Camcorder
Cannot load a tape into camcorder. I have tried two separate tapes, neitehr of them load in to the camcorder. A message comes up: "remove the cassette" when it has not even been loaded properly.
  • Anonymous Mar 22, 2014
    RCA Pro 865 camcorder not working properly
  • 18 Answers
I had the same problem. Checked the site and found a solution of dropping the camera onto a carpeted floor from about 1/2m to 1m. Thought that it was bullsh1t but was desperate and so tried it. worked a treat!!!
Hope this helps.
Posted on Aug 13, 2009
  • chrisjones30 Nov 16, 2010
    I had to drop it about 6 times. But now it works. I was just about to throw the camera in the bin
Hello to all canon holders!
I have a friend ho's working at canon services... and !!!! the solving problem was to shake it wery well... ad if isn't soved drop it down on an carpet!!!
(the specialist advice :))))) )
Posted on Jan 12, 2010
  • pkb77 Dec 18, 2010
    I shoke it first: didn't help.
    slapped it a bit roughly on the side as if it would fall from 1 meter: worked in an instant!!!
    thanks.
Like Ronin99 I was very sceptical about dropping the camera, but in a last ditch attempt before buying a new one I did, and wish I'd done it a couple of months ago as it now works fine!
Posted on Sep 03, 2009
As impossible as it sounds, dropping works. I thought it was crazy, but I read all the solutions and decided to try it. I have a "safe bag" that I bought for storing my binoculars, full with foam. I inserted the camcorder in it, dropped it once from a height of approx 80cm and it worked. Thanks ppl.
Posted on Nov 21, 2010
  • lwright525 Apr 23, 2011
    I was skeptical but it worked! Just bashed on my leg a few times & it didn't work. I tried on the side & with a bit more force (not too hard though) & then it worked. Doing it on your leg is good because the pain will guide you as to how hard to hit. If you're hitting hard enough to make bruises then that's probably too hard. Thanks for posting this.
I would just like to add weight to the advice of dropping it from a short height onto a carpeted floor. I could not believe it, but it was the only thing that worked!
Posted on Jun 15, 2010
  • mike balch Aug 16, 2010
    To provide even more support to this solution - yes it does really work. I would suggest that this should only be done dropping it onto the bottom (as you would normally hold the camera) of the device as otherwise you might actually break something. But the strongest part does appear to be the bottom and taking the prescribed advise did in fact work well for me.
Can'tbelieve it! after several months of frustration of not being able to load a tape into the camera,I read this wierd idea of dropping the camera. I thought this sounded rather drastic so gave it a couple of good hard slaps on the bum and WOW it worked a treat.
Posted on Jan 11, 2011
  • shugli Mar 09, 2011
    I had the same problem and the solution worked for me!
    Problem Solver:
  • 5 Answers
In the guide (one of the first few pages) it tells you which button to press to enable a load. make sure you put good (but dont force it!).
Posted on Jul 14, 2009
Yes, as mad as it sounds, dropping it works. I had to drop it twice. First time nothing (from about 70 cm), second time ( 1 metre 10 or so) result!!
Posted on Sep 01, 2010
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com.
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Code: 31:23....please reinsert tape. everytime i switch it on.
dear
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Jun 22, 2009 | Sony Handycam DCR-TRV265E Digital...
Jvc miniDV 28x Optical Zoom
clean all brown oxide off capstan roller with 70% alcohol and Q-tip. Its the skinny silver axle that the rubber roller comes into contact with when the tape loads. This is what pulls the tape through the transport. also clean heads with head cleaner tape. If your head is dirty, the tape will wrap itself around the drum and cause a transport error.
Jul 14, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Cant put tape in camcorder
Then remove the tape and check it in another camcorder.....
............. Very simple.
If the tape works fine in another camcorder then throw this camcorder. Let me know the location where you will through it.
May 07, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
Dec 17, 2007 | Canon MVX200 Mini DV Digital Camcorder
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Tape will not load
I have enabled the MV6i to load a tape by: replacing the 3V 'data' battery, re-entering the date and time, turning the camera off for about half an hour, after taking several photos using the photo function the tape would load properly. Hope this works for you too! jimtarver@ntlworld.com
Mar 07, 2007 | Canon MV6iMC Mini DV Digital Camcorder
Canon DV-MV830i Mini DV Digital Camcorder Logo
749 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
