Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
No controls The pool is stuck in maintenence mode. None of the control panel button do anything. Is this locked out??
  • 128 Answers
Outside control panel is in service mode. Put in Auto
Posted on Aug 30, 2009
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Cannot get temperature buttons on hot tub to change
Do the other buttons work? Is the control panel locked, some spas have a control panel lock to prevent kids from playing with the temperature. Are any of the buttons stuck in the de-pressed/down position? If neither the problem is likely in your topside control which means it will need to be replaced.
Sep 18, 2012 | Pool & Spa
Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Dec 31, 2011 | Dream Maker Spas Pool & Spa
I have a hayward 400idl heater that is stuck in stand by mode. any ideas?
Hi
If you have a auto control system like a Aqualink,Aqualogic Put the controller in service than select heat. Check and make sure the service light is not on also. What happens when you press the mode button. If nothing and the button membrain looks good. open the front panel there is a ribbon cable that goes to the display and plugs into a control board in the back. Unplug the cable and plug it back in "Be Careful The Pins bend very easyly. Try the mode button again. Is there any error codes on the display?
Jan 07, 2011 | Hayward H-series Electronic Gas Pool...
I have an aqualink RS6, when i press the waterfall button, the display reads locked out. how do I remove the locked out
If your trying to turn on from a inside or spa side controller, then most likely the main control panel is either in time-out, or service mode. When the main controller is in either of these modes it locks out the other controllers. This is designed so if a service tech is working on the system, a user cannot turn something on. Try looking at the main controller and look for a mode button. It will toggle between, auto, time-out, and service. auto is normal operation, time-out should suspend the system for about 3 hours, and service mode suspends the system indefinitely until the mode is changed.
Sep 19, 2010 | Pool & Spa
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have LOC on the control panel and I am not able
To Unlock Main Control Panel: Press DISPLAY, MODE, and DOWN buttons within five seconds. The “lock” symbol will disappear. All buttons are now active.
Sep 17, 2009 | Pool & Spa
On light does not glow and can not "stop" the system
the rain shouldn't have hurt the control panel. it sound more like damage due to lightning.
Jun 07, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
GHW9100LQ1 machine stuck in control lock mode
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
228 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
