Soyo m/b model sy-p41 845pe.
I have a soyo m/b model sy-p41 845pe. Purchased 1997. Battery ran out recently & I lost my Bios settings. I cannot set boot sequence. I cannot prevent floppy seek. I forget what I did 12 years ago to succeed. Please help! Bios comes up but complains and ignores resets. Thank you! Eugene
    Scholar:
  • 111 Answers
Eugene, how are you? Not a problem, firstly have you replaced the motherboard CMOS battery? If you have the next step is to boot into the BIOS, most of the time it will mean pressing the delete key, or F8,F10, F12 and or ESC upon turning on your syst. It all depends on what kind of pc you have.
Once you are in the BIOS setup screens go through each one and just remember to save and reboot your syst. This should set you straight. ;)
Posted on Jul 14, 2009
  • rebelbw Jul 14, 2009
    Eugene, in all fairness I went back and did the research. The company who made your motherboard has closed up shop and the mobo with chip is kind of dated, so I have picked a viable replacement motherboard + cpu if you care to check it out. Most likely the only other item to replace will be your power supply. The one you have will definitely not support the new setup. Enjoy.
    http://www.directron.com/biospecial.html
I changed some BIOS settings for CPU speed and memory, now it wont boot - how do i reset the BIOS back when I cant get to the BIOS screen? Soyo K7V Dragon motherboard
Hi:) Turn the computer off but leave it plugged in so you have no static problems. Open the computer tower and on the motherboard near the Cmos Battery there is a blue or red jumper that covers 2 of 3 pins move it to the other side of the 3 pins for 30 seconds then put it back that will reset the bios to default.
Mar 07, 2011 | Soyo SY-K7V Dragon Motherboard
Soyo k7v dragon plus motherboard continuous
Hi Jopav1,
At the age of *********** board, I would recommend physically looking at the board, in particular, the large upright capacitors. If the tops are bulging, or have anything leaking out of them, send the board to a recycler, and look for an exact replacement on the used market, or replace with new. I just bought the same board you have today for $25, with AMD 1800 CPU.
At 10 years of age, the battery is probably past due for replacement too. It is a standard CR2032 3Volt battery. If you replace it quickly, you may not loose your BIOS settings.
If you have a volt meter, you can check your power supply voltages. Again, your manual will show what voltages to expect at each power connector pin. A range of +/- .05V is generally allowable on all sources.
Also try unplugging all boards and powering it up. The beep should change to a sequence of 2-1-3-1 beeps, indicating that it's not able to see the video card. If you still only get a repeated long beep, It's possible that the CPU itself may have died. These are also available very cheap at this point. The fact that you are getting a cycling beep indicates to me that the CPU is OK though.
I looked up beep patterns and did not find anything for one long repeating beep for the Phoenix BIOS on your board. There is no mention of them in the Soyo manual either.
Last resort is resetting your BIOS settings to "First Birthday", and try again. This will require you to re-set any manual settings you had set previously (probably 10 years ago). This is done by moving the jumper located between the green LED, and the battery, to the two pins nearest the LED, for a second, and then back to the position nearest the battery.
Good luck
Video Flyer
Mar 22, 2010 | Soyo SY-K7V Dragon Motherboard
Soyo SY-P4ISR Motherboard just beeps at me.
put the clock speed to auto or, check your cpu speed and set it up manual in bios
Jan 12, 2010 | Soyo SY-P4ISR Motherboard
Manual reset motherboard: Soyo SY-K7VME
Bios settings are retained by the Motherboard Battery in the CMOS. Disconnecting the battery clears CMOS and returns the settings to their original state. Typically this can be done by simply removing the CMOS battery and waiting about 15 seconds before reinserting and booting PC. Nowadays most Motherboard manufacturers supply a jumper to not only disconnect the battery but also ground the CMOS to effectively drain any residual power.
The instructions for your MB are found below. JP5 is located to the left of the battery and next to the PCI 2 slot on your MB. There is a Manual for your MB on this site and the MB layout can be found at
http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-5
Follow the steps below to clear the CMOS memory.
1. Clear the CMOS memory by momentarily shorting pin 2-3 on jumper JP5. Its white cap can easily identify this jumper.
2. Put the jumper back to 1-2 to allow writing of new data into the CMOS memory.
Jan 07, 2010 | Soyo SY-K7VME Motherboard
I have a SOYO Sy-CDA Mother board and it will
update your bios there is a problem with that board not seeing the usb keyboards from time to time
Dec 02, 2009 | Soyo Computers & Internet
SOYO's SY-P4VTP with 3GHz Pentium 4 Processor does not bootup.
check the rams and if they are ok
try to reset the bios settings from the motherboard jumper settings. like clear CMOS jumper will be there.
Apr 17, 2009 | Soyo (SY-P4VTP) Motherboard
SOYO SY-7VBA133U cannot adjust CPU speed
Flashing the bios is the best idea to start with. This will upgrade to the newest bios, which normally adds more features and fixes some bugs.
There is a small chance that this motherboard just doesn't support overclocking, but the majority of them do.
Below is the link to soyo's site and downloads for your model number. There was 4 or 5 bios updates. I would get the newest one.
http://www.soyo.com/content/Downloads/155/&c=28&p=48&l=English
Hope this helps
Mar 21, 2008 | Soyo SY-7VBA133U Motherboard
Sy-7vem soyo cpu upgrade
Most of the new boards will automatically detect the cpu speed. If possible set the bios to auto detect. Otherwise go to Soyo website and check the manual
Dec 21, 2007 | Soyo SY-7VEM Motherboard
Computers & Internet Logo
481 people viewed this question
David Payne
David Payne
