Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Posted on Jul 30, 2009
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
I have cub 1020 lawn tractor hydro, started not moving in reverse, but now will not move forward or backward any suggestons?
Have you Inspected your Belt? Your Drive Belt and Pulley's need to be inspected
Apr 14, 2013 | Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't move
check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Jun 22, 2009 | Garden
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
483 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
