Question about Sega Viking: Battle for Asgard for Xbox 360
How do you open the gate - Sega Viking: Battle for Asgard for Xbox 360
    Problem Solver:
  • 11 Answers
Use a grim reaper pole and slice it or cheatcc.com
Posted on Jul 14, 2009
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
Why liftgate acuator clicking when lift gate is open
I would bet on the liftgate module (LGM) It controls all that stuff back there,wiper,defrost,gate ajar light,gate lock and unlock ect. Might try wiggleing the wiring boot where the wires go from the body to the gate,if it changes anything,bet on a broken wire inside that boot.
If not the LGM is my first thought.
Feb 15, 2015 | 2004 GMC Envoy
Open electric gate manually
if no power to gate opener..unbolt the gate from the chain and open it manually..may have a power outage..
Jan 11, 2014 | Home Security
Gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Mar 05, 2013 | 2010 Jeep Liberty
Can I open the rear glass when the gate is open. I have a large item that needs to get into the car via the gate, but I only need the window open after that. If not ... how do I get it done (forcefully)...
You should be able to open the window and the gate. If the window won't open while the gate is open, try opening the window first, then opening the gate.
Good Luck!
~Brandon
May 29, 2011 | 2005 Mitsubishi Endeavor
How to install the Evenflo 42'' position and lock gate
  1. Measure the opening where you want to place the Evenflo gate. An Evenflo pressure-mounted gate will work for an opening between 26 and 42 inches wide.
  1. Pull the cross bar up on the Evenflo gate so that the small metal sizing bar is movable.
  2. Place the metal sizing bar into the slot that matches the measurement of your opening. If your opening is not a full inch, round up to the next full inch and place the sizing bar in this slot.
  3. Set the Evenflo gate in the opening with the cross bar facing away from where your child will be. Make sure the pressure points are above your baseboards.
  4. Press down on the crossbar until the metal U-shaped clamp catches the bar.
  5. Test the gate by gently pushing and pulling on it to insure it stays in place.
Feb 28, 2011 | Evenflo 42" Position & Lock Gate
Every time I enter my gated community, I have to input the security code to open the gate. I have seen other drivers open it with a remote control, so I bought this remote because it said Gate opener in...
Hello, XdLucas -
Check with the management office for your gated community and ask your questions. There may be a specific gate opener you need and a specific code, which the management staff will provide.
Best wishes.
Feb 11, 2018 | Chamberlain 3Button Remote Control Model...
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
Gate wont open, lock and unlocked still wont open
it may be that the gate has dropped on it's hinges, try lifting as you open. (i assume a side opening gate)
Oct 01, 2009 | 2002 Ford Escape
Sega Viking: Battle for Asgard for Xbox 360 Logo
49 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
