Question about Intermatic & Indoor/Outdoor Rain Tight Timer
How do to set the timer on and off on a sangamo model q346-1-126
I have two Intermatic wall switch timers: Easy set timer model SS7 and one with number 154ST24898. Any idea ho to program these?
Crystal Air ozone machine support
https://www.bing.com/images/search?q=easy+set+timer+model+154st24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&FORM=IQFRML
Nov 13, 2016 | Intermatic Hardware & Accessories
Setting a timer model hb88rc75
http://waterheatertimer.org/Woods-timers-and-manuals.html#HB
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Manuals for the Intermatic are located on links above.
If your timer does not show, then attach photo of product
If you have specific question about setting the timer, add a comment March 2015
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Dec 11, 2014 | Hardware & Accessories
How do I set a Outdoor Timer Model 23ULD/3AOType 3R
Copy following link to identify timer, and see instruction manuals for each type:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
h
Dec 08, 2013 | Woods Outdoor Lighting Timer
How do i use the diehl m111-8 timer and how to set it
1) Copy following link for Diehl timer manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
2) Model number given does not match known product.
Google search shows fixya on first page result, implying there is no information on this model number timer.
Add comment and describe timer in detail.
Feb 17, 2013 | Hardware & Accessories
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
283 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
