I have a leaking hose at the top of my Kenmore elite washer. Only way to get to it is to pop the top of washer off. How do I get the top of the washer off?
  • roro65 Jul 15, 2009
    The make is Kenmore Elite, model # 26922502, top loader. There is a hole in the hose that delivers the water to the tank. It's directly underneath the control panel. (I believe a rat chewed the hose) I just need to take the top of washer off (including the lid) to be able to reach hose and replace it. I just want to see if I can remove top myself without calling repairman.
    Thanks
    President:
  • 1,462 Answers
Hi ,
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Jul 15, 2009
  • 3,230 Answers
What is the make and model number of your washer?
i think you need to replace the whole bleach container and hoses.
Thanks
Posted on Jul 14, 2009
Kenmore elite washer leaked water all over floor
anything that uses water can leak . you have to look for where it came from and fix what ever you find .could be the pump or just a loose hose .
Sep 30, 2015 | Kenmore 24032\24036 Top Load Washer
It leaks
where does it leak from,could be drain hose, or pump or connections to and from drain hose and from pump,, look for rusted clamps under neath,,,or holes, also chek waterhose connections,when loking underneath chek for water spots on hoses and pump..
Oct 10, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
Jun 13, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite
could be spash over be sure washer is as level as possible
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
