Question about Compaq Presario R3000 Notebook
I just came back from a few weeks away and discovered that my laptop is dead. It won't switch on at all. I would be very grateful if you could advise me what to do please. Thanks.
All the Best,
Tony Hackett
  • Biggybrain Nov 17, 2007
    Thanks very much! I removed the battery and hit the power switch and the laptop started without a problem.
  • 85 Answers
If you are getting no lights at all on the laptop, you need to check the "powerline" - everything between the outlet and the back of the laptop.
Start by removing the battery. Then, check to see if the power pack has an ON light, if it does, make sure it is on, if it has a light and it is off, try plugging the power pack into a different outlet you know works. If it is still off, you have a bad powerpack and needs replacing. If the powerpack does not have a light, you need to find a geek friend with a multimeter (or get one at WalMart for $4), and check the powerpack's output in volts matches whatever it says on the side of the pack. If the voltages do not match up (generally) you have a bad powerpack. If you are getting normal voltage from the powerpack but the laptop is not getting any power, you have a different set of problems. Is the laptop beeping when you try to turn it on? Do you get any activity at all?
Good luck...
Posted on Nov 17, 2007
  • RIchard Wheeler Nov 17, 2007
    Try charging the battery for one hour with the laptop off; if it does not charge, one of the cells in the battery pack has gone bad, and you need to remove the pack and recycle it; don't leave the bad pack in the laptop or it will lead to trouble...
Compaq presario r3000,bios problem restart.plesase resolve
Did you install any software's or re installed the operating system?
Dec 25, 2010 | Compaq Presario R3000 Notebook
No driver for sm bus, system management bus Compaq Presario R3000 laptop with AMD processor
You can find the bios driver for your laptop HERE. Since your updating drivers you might want to update all of them, that way you've got a current system.
Good Luck
Mar 07, 2010 | Compaq Presario R3000 Notebook
Where is my wireless switch on my Compaq Presario R3000
Right side in the front at the corner ,,little round button ,,it will glow blue when on,,
Dec 13, 2009 | Compaq Presario R3000 Notebook
Hi!I'm useing compaq presario R3000,so i would like to know can I use 2G ram for upgrade n set up window 7?
log on to - let it scan your machine and it will give you memory upgarde options
Dec 04, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Where is wireless connection switch on Compaq Presario R3000?
Well if u have the same exact one as myself.
The wireless button is on the front right near the corner. above it and on the corner is the wireless symbol. If its working it should be lit blue. push it and see if it lights up blue for a few seconds. You should get a wireless connection confirmation on the screen.
hope this helps you
Nov 10, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
Compaq Persario R3000
i have a problem can you please send me a atachment of this driver base system device so i can instal it to my laptop compaq presario r3000
my email is
Sep 04, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 PC
Hi Tom,
It appears without looking at the laptop you have removed or dislogged the cable that goes between the motherboard and the screen. This is not hard to do they are very delicate. The only thing you can do is take it to a qualified service tech. i get these periodically in my shop too. Check the cable before you do so to see if you can reconnect it but be very carefull.
Be mucho blessed,
Jul 18, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
160 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
