Question about Car Audio & Video
Need a front for my clarion drb3675r stereo - Car Audio & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try pacparts.com
Posted on Jul 15, 2009
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
you need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Mar 24, 2014 | Clarion NX602 In-Dash Car GPS Navigation
Need the wiring diagram for a Clarion RDX755Dz stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html#ANCHOR9 This is the basic wire diagram for all Clarion stereo's Clarion uses the industry standard wiring colors.
Jun 29, 2011 | Clarion RDX655Dz
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
SECURITY CODE NEEDED FOR CLARION CAR STEREO
www.radio-code.com/ -
www.radio-code.com/UnlockManu.htm -
floodle.net/extra/ebayinfo/car_radio_decode.html -
Those should sort you out.
Mar 25, 2010 | Clarion DB245 CD Player
Need a wiring diagram for a clarion drx 5275 car am/fm cd player
COLOR FUNCTION
You may not have all the wires on the stereo but this list will help. Good luck and please rate.
RED ACCESSORY
YELLOW BATTETRY
BLACK GROUND
BLUE POWER ANTENNA
BLUE/WHITE AMPLIFIER TURN ON
ORANGE ILLUMINATION
ORANGE/WHITE DIMMER
GRAY RIGHT FRONT +
GRAY/BLACK RIGHT FRONT -
WHITE LEFT FRONT +
WHITE/BLACK LEFT FRONT -
VIOLET RIGHT REAR +
VIOLET/BLACK RIGHT REAR -
GREEN LEFT REAR +
GREEN/BLACK LEFT REAR -
Dec 02, 2009 | Clarion DRX5275
I need to know what wiring harness i need for a clarion stereo model db365usb?
try this
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Sep 25, 2009 | Clarion DB365USB CD/MP3 Player w/USB
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
I NEED A FEW THINGS FOR MY CLARION STEREO
Go to pacparts.com and you will find any CLARION accessories
Dec 18, 2007 | Clarion DRX6375
Car Audio & Video Logo
263 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
