Question about Whirlpool Dryers
Whirlpool dryer LER5636PQ0 push to start keeps failing to work
Push to start would not push,so dryer wouldn't start. I installed a new one thaat worked fine for one load, but the same thing happened. The thermal fue tested OK , there was not much lint buildup, and all connections are tight. I purchased another new push to start switch, but I don't want to install it until I find out if there may be something else causing the problem
  • Whirlpool Master
  • 1,606 Answers
You could have a worn door switch . Push in on the plastic piece which closing the door actuates and press the start botton . If it starts ,several times , then replace the door switch . Pt # 3406107 . Do this after you put the 2 thermal fuse (slim white piece with 2 wires attached )wires togather for testing purposes only . BE sure to unplug dryer before doing ANY repair testing first ! If it starts by jumping the wires , then pt # 3392519 fot thermal fuse .
Posted on Jul 19, 2009
I have new dryer Whirlpool duet push the button it turn on but push the start button and it does not work
dryer under warranty just CALl the company got from an they send service tech out
Feb 15, 2015 | Whirlpool Dryers
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
My LER5636PQ0 wont heat up but it does run. Also the timer does not work or buzz when cycle is done. Help?
Check for blockages and correct that first7767bef.jpgThen unplug your dryer and remove the rear cover. This is your dryer.070f137.jpgafter you clean it up check the fuse0d461b2.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 04, 2010 | Whirlpool LER5636P Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
E-1 dryer just stops till you push it to start
HI, the thermistor has failed. have this damaged temp sensor replaced asap. this will fix your issue.
Aug 24, 2009 | Whirlpool Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Dryers Logo
281 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
