Sharp AR-407 Grayscale Copier
Problem for Sharp AR-407 Grayscale Copier
Can I get rid of the error H4-01?
By patricia251 on Jul 14, 2009
Best Solution
posted on Jul 15, 2009
Very Helpful)
lbcoaster
Rank: Guru  Sharp Expert
Rating: 93%, 154 votes
Hi, The H4 means the copier (fuser) does not reach a specified temperature within a given time.
This could be a bad or dirty thermistor or a bad heater lamp or a bad control board or AC supply.
The first thing to do is reset. To do this enter service mode by pressing the following keys one after the other (make sure you are in copy mode) "P" "interrupt" "C" "interrupt" then enter 14 and execute the reset. then press the C/A (Clear All) button to exit.
If problem persists you should then have a service tech take a look at it. Hope that helps... Lbcoaster
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Sharp AR-407 Grayscale Copier
Questions and Unsolved Problems for Sharp AR-407 Grayscale Copier
Do you recommend Sharp AR-407 Grayscale Copier?
Answer
Answer
my mita dc 1260 copier has failed to get into simulation mode
Answer
I accidentally erased my brother printer information and need it reinstalled.. what do I do?
Answer
My Phaser 8560 has colored lines down one side of document?
Answer
Hello. Each time I print the paper gets jammed in the roller located inside of the second drawer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AR-407 Grayscale Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 780
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
