Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Water Filter Item # - Jenn-Air JSD2789GES Side by Side Refrigerator
  • 34 Answers
Jennair parts are now made by Maytag, part #UKF7003 available at www.partstore.com
Posted on Jul 24, 2009
WHEN YOU CHANGE FILTER DO YOU NEED TO RESET LIGHT ON DOOR OR WILL IT RESET ITSELF AFTER CHANGING THE FILTER
Posted on Jul 18, 2009
I have no hot water, how do I change the filter in a Bock Water Heater 32E 32 gal oil-fired hot water heater ?
Unfortunately, looking at the manual for the water heater, the filter is a separate item. And the recommended Delavan line filter page just shows a picture and part numbers of the item, not how to remove it.
I suspect it works in such a way that you hold the end nut portion and turn the large nut portion with open end wrenches. You will need the internal filter replacement and possibly new seals, probably in a kit.
Line Filter
You'll want to turn off the power to the oil pump so you don't make a large mess.
Jul 20, 2016 | Water Water Heaters
Where can i get a new filter?
a filter for what?
for a vehicle --try and auto spares shop
for a laundry item -- try an appliance shop
for a water item --try a pool shop
May 04, 2015 | Cars & Trucks
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
I HAVE A MAYTAG DISHWASHER MODEL- MDB5000AWA. IT PUT OUT WATER BUT SPINNER INSIDE DOES NOT SPIN.
Their is a couple possibilities
1) the water level in the tub is insufficent. It should be level or just above the heat element. If not at that the level as long as water pressure to the dishwasher is good the water inlet valve that the water supply connects to is bad
2) the filter inside of the pump is clogged and water is having a hard time getting into the pump to circulate. This link http://c.searspartsdirect.com/lis_png/PLDM/M0203021-00006.png shows where the filter is (item#6) to get to it unscrew the tube on the top of lower wash arm(not shown is the drawing) remove item#2&36 then item #4 to get to the filter
if water valve needs replacing its part#99001359 it could be purchased at your local appliance parts store or online at;
repairclinic.com
apdepot.com
assuredparts.com
Good luck,i hope this helps,
Gene
Aug 04, 2011 | Maytag Dishwashers
What is part number for water filter?
Hello there:
Water Filter
Item # 1017291
$35.75
Item # 1017291
img-descriptiontab-on.png Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Related Items:
Jan 26, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Washer will spin but not drain
Hi from retired Englishman in France,
Drain pump filter blocked? This is the case in so many instances!
POWER OFF AND HAVE SOMETHING TO COLLECT THE WATER!!!
I am presuming that this is a front loader (which is what we have always purchased).
Panel front, bottom to be removed. Sometimes there are (2) plastic 'screws' which turn only 45 degrees to loosen or the panel is simply 'clicked' off and on.
There will be a circular turnable item behind which the filter sits. Remove this item BUT- beware of the water because often the filter is (temporarily) attached to the item and water will pour out.
Obviously remove anything in the filter (worth doing this regularly anyway!) and at the same time the pump itself will be visible. Just make sure it will rotate and nothing has managed to get through the filter ( a sewing needle for instance) and jam it.
If the water still does not drain the pump could be malfunctioning- new pump.
Good luck,
John C
Jan 25, 2011 | Admiral Washing Machines
I need a replacement filter for my kenmore coffee maker item#69768
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
What water filter does it use?
hello there
Item #
1446373 Price
$41.65 In Stock?
Yes Maytag/Amana/Jenn-Air PuriClean II Refrigerator Water Filter - The PuriClean II water filter is manufacturer part number UKF8001AXX. It is a high-quality carbon filter that reduces contaminants such as lead, cysts, pesticides, herbicides and much more. Replace annually or when the filter light is on.e643401.jpg
Jul 27, 2010 | Maytag MSD2656G Side by Side Refrigerator
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Water dispenser is dispensing water at a trickle
The water filter is the first item I would check. I just repaired a s/s with the same problem and it was the water filter.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
178 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
