Question about ASUS P5S800-VM Motherboard
P5S800 board wont post. I have tried with onboard VGA and with video card. It seems the pc wont go to POST. It just beeps continually. 1 long and 2 short. I have reseated the RAM and tried different RAM. I have also tried a different PSU as the fan on the other one didnt work. Is it possible when the fan went down it burnt something out on the board. My other thought is its a fan alarm teling me the fans not working
    President:
  • 1,179 Answers
That beep code is either a RAM or Video card issue depending on motherboard. It may be that when the fan went down it burnt out the video card slot & onboard video. Without physically seeing the board I couldn't tell for sure, but that is definately what the beep code is pointing to. Also make sure that when you are using a video card that you have the 6, or 8 pin power plug connected to it. As well as making sure both the main 20, or 20+4 psu plug and the 4, or 8 pin psu plug are connected to the mb. Hope this helps.
Posted on Jul 14, 2009
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
Mar 11, 2012 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
It is not showing the post screen and beeping a long and continuous beep
a long beep is identicated your vga has trouble, but maybe it caused by ram error, first turn off your computer, open computer case, disconnect your ram and connect again, turn on computer, is the computer still beeping??if yes it mean the problem come from your vga card, do not use onboard VGA port, just insert PCI or AGP VGA card, your computer will work properly
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Foxconn (945G7MA-8KS2) Motherboard
No signal to monitor.all connections and videocard seems ok fans work , What can be the problem? send a Trouble Shooting chart please
Okay here are the steps.
1. Turn off computer and restart it with tapping F2, the BIOS screen should come up. 2. If that does not then your computer is not clearing the POST or Video part that comes right after post. 3. Take the video card out and connect the monitor to the On-Board card on your motherboard. 4. If that works then there might be a problem with your video card. 5. If that does not then there is some more troubleshooting to do, try take the memory cards out and see if the motherboard beeps. This is to ensure that it is working fine or not. Put them back in and then try to turn on the computer.
Reply if need more help.
Thanks. If this was helpful, then kindly rate me.
Nov 01, 2010 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
Bios problem
Sounds like the wrong BIOS programme has been installed. Not a lot can be done about that apart from removing the BIOS chip and reprogramming it with an EEprom Programmer. Purchase a new motherboard is the answer.
Mar 12, 2017 | Intel Computers & Internet
No post, only motherboard light on, green.
Hey there aj1253, It seems you are getting power to the board. are the fans running?Are you using onboard video or video card. Onboard is suggested for test. I would also suggest you reseat your ram. That is removing it and ensuring it seats properly. Beyond that I would ask you provide more info ( ie is this a new build, or did it just stop working, configuration details, model #'s, et....)
Feb 01, 2008 | Dell Dimension 2400 PC Desktop
ASUS P5S800-VM Motherboard Logo
182 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
