Question about Hotpoint Dishwashers
No water getting in. main water line is ok and tested
  • Hotpoint Master
  • 19,396 Answers
Test the inlet valve and the water level switch.
The inlet valve can be tested reading continuity on valve solenoid contacts, check also the water level switch actuated by a floating sensor.
If they are ok then the problem is usually the timer control board. Testing this part is more complicate and is done reading voltages.
Always keep your appliance unplugged when you DIY.
Regards.
Posted on Jul 14, 2009
I am getting water leaking from under my fridge freezer it stops when I turn the mains supply off for the water filter.
I would check the water lines that supply the water to the fridge, and any visible lines on the fridge itself. I used to have a problem where the plastic lines would get brittle and snap at the ends - I also use a product called Floodstop that has sensors that automatically shut off the water to the fridge if any of the sensors detect water leakage - plus it tests the valve once a month to make sure it actually works when you need it too -
Oct 07, 2017 | Refrigerators
Fridge is freezing over and no water or ice.
I would check the main water supply coming into the fridge first. If there is water there then make your way into the fridge. Try to confirm the supply in the fridge by looking at the line into the fridge. If there is water there then you need to check the door switches to see if they are supplying power to the water solonoid. But if the fridge is not making ice also I would look at the main control to be the problem. But if the freezer is running too cold then the frost level in the insulation could reach the water lines and freeze them. But if the freezer is running too cold then I would again look at the main control as being faulty. No real way to test the control, unfortunately you just get to replace it. Hope this helps
Sep 08, 2012 | Whirlpool Refrigerators
Power on. red light flashing. water not heating. no change after 20 mminutes.
hi u need a multimeter to test parts .. take bottom off (MAKE SURE ITS PULLED OUT OF MAINS ALSO NO WATER IN IT ) U WILL GET WET :) now take connection off element and test for contunuity if ok test stats the same way..if ok check theromo link change part that is open circuit..hope this helps. 07779933829 uk
Feb 23, 2011 | Coffee Makers & Espresso Machines
I have problem regarding water tapping in indoor unit of split a.c.
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
hope answer the question
please vote!
Jul 07, 2010 | Whirlwind FH-778 Air Conditioner
Dishwasher will not wash.
Ok, i recommend testing the circulation motor for its operational value. if the motor is functional, replace the main control board or timer.
Jun 13, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
My dishwasher wont drain out? any ideas?
Start checking drain hose first.
Check water level switch.
If water level is ok check drain pump lines , and test drain pump.
If everything else is ok, test the control board (uncommon).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Kenmore Dishwashers
Whirlpool HE WFW9200SQ00 is Dead
control unit dead, replace main control and possibly user interface. Sorry this is very common failure on whirlpool.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hi I have just bought a LG GWL227YVQA. All plumb in and the water is from the mains, however after 32 liters of flushing out the system the water still tastes like poo!!! It a new fridge and filter any...
HI,
Tested the water with out the filter and straight from the tap...ok
Tested the water through the fridge without the filter...ok
Tested the water with the filter back on...NOT OK
Problem filter is pants!!!! require new filter.
Apr 07, 2008 | LG Refrigerators
Dishwashers Logo
94 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
