Question about Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum
Vacuum not suctioning properly and dirt is not reaching cannister.
  • 867 Answers
For sure a clog some where in the hose most likely, or where the hose enters the vacuum
Posted on Jul 14, 2009
My Dirt Devil Envision #086710 is not picking up. Hoses clear, new belt, brush cleaned of hair etc. Air leaking from the place where the cord comes out of the vacuum at the bottom is this normal?
Sounds like you may have a hole in a hose somewhere. Check the internal hoses and make sure they are connected correctly. Check that your cannister is locked in. This may be preventiing suction also.
Sep 27, 2014 | Dirt Devil Envision Vacuum Cleaners
Dyson DC25 is barely picking up, but what it is picking up is not going into the cannister,
Your problem is posted in the wrong category, so probably no-one reading here (Telescopes and Binoculars etc) will have the solution.
I do know that Dyson maintains Tech Advice lines worldwide. Look here
http://www.dyson.com/
select your region, then look for a Tech Advice number you can ring
Jun 10, 2012 | Dyson DC25 Ball All-Floors Upright Vacuum...
Loss of suction
If it is running and you have no suction, there has to be a clog in the dirt path. To clear it, start at the head of the vacuum (where the dirt goes in) take apart or disconnect everything you can along this path until you arrive at the bag or cannister. Take pics with your cell phone so you can reassemble it. Hoses: run a broom handle through all hoses to assure they are clear. If you have a shop vac or similar, try applying vacuum to all parts of your disabled vacuum in reverse. Are there filters on your machine? Make sure they are clean. You probably don't have hoses connected, but if you do, check them as I said.
I pick up vacuums along the road all the time. Very few are more than a few months old. All of then have a clog in the hose or elsewhere in the dirt path. I clean the path and sell the vacs for a slightly discounted price. VERY rarely is it a motor problem.
I hope you find this comment helpful. Here they are in under 5 minutes. Thanks for using FixYa.com
Jun 27, 2011 | Kirby G5 Bagged Upright Vacuum
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Turns on but does not want pick up anything.Suction is good but the garbage does not go into cannister.
The reason it is not picking up is because the belt is stretched or worn. You simply need to replace the belt. you can get belts here:
Dirt Devil Belts
Feb 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt does not collect in container....collects in filter area
Small Filter at bottom of cannister may be clogged. Not letting enough suction draw dirt down.
Dec 22, 2009 | Eureka 5856BVZ Boss Bagless Upright...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum Logo
263 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
