I have an LG LSN122HE model A/C in my office. It doesn't matter how far down I turn the temp, it continues to blow room temperature air. Suggestions?
  • 867 Answers
Seems like the coolant leaked out, second, unlikely thermostat is defective
Posted on Jul 14, 2009
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
2006 Honda odessey air condition going from blowing cold to just room temp air
Does it start off blowing cold then goes to room temperature, or was it cold and now any time you turn it on its room temperature
Dec 14, 2014 | 2006 Honda Odyssey
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressora73b784.jpg should shutdown when setting temp. will attain.
Apr 08, 2008 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
