Question about Kitchen Ranges
Main Oven will light and remain on, however there is no temp adjustment even after a time delay Model Parkinson Cowan SIG 454
    Scholar:
  • 83 Answers
Hi
The problem you have is this:
The FSD (Flame Safeguard Device) is faulty. This is what it does....
When you turn your oven on the FSD allows a small amount of gas through to the burner, the lit gas heats the FSD and says yay we have gas!, it then lets more gas through!
If it's broke it just keeps it on low flame.
You need to get a qualified Gas Engineer to look at it for you
I hope this helps
Steve :)
Posted on Jul 14, 2009
How do I change to he top element in my Parkinson Cowan RM850 GRN
turn off all electric remove left side panel you should see element there would be 2 screws holding the element fixture and one inside oven once screws are removed then element should slide out of oven new one justs slides in to replace
Dec 30, 2010 | Parkinson Cowan RM850 Dual Fuel (Electric...
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
Cant regulate main oven temp, always burning at high fire
Hi sounds like the oven thermostat has gone needs new one
Apr 23, 2009 | Parkinson Cowan SG555 Gas Kitchen Range
Parkinson cowan sonata 55x gas cooker
When foods come out burned, soggy, or unevenly baked, it generally means heat isn't being distributed evenly throughout the oven, it's escaping out the door, or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven.
2) Check the door gasket, and, if necessary, replace it.
3) Be sure nothing is obstructing the vent.
4) Reposition the oven racks so baking pans aren't too close to the heat sources.
5) Check your baking pans. If they're dark, they may be burning your food. Reduce the temperature by 25 degrees Fahrenheit when baking in dark metal or glass pans.
You can also recalibrate the controls. If your oven has calibration right on the knob, you can calibrate the appliance as follows. If it doesn't, call an appliance repairperson. To adjust the thermostat's calibration:
1) Remove the oven temperature knob by pulling it off its shaft.
2) Notice the current setting, and then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer on some models; if this is the case, you'll have to remove a couple of screws. Figure that moving it one notch will change the setting by 10 degrees Fahrenheit.
3) For more accurate calibration, call an appliance repairperson.
Do rate the solution i need it!!
Jun 17, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Will not ignite
have a parkinson cowan renown model RG60SS, about 12 years old. automatic ignition does not work - no sound or anything.. please help!!!!!
Dec 30, 2007 | Parkinson Cowan SG340 Gas Kitchen Range
Kitchen Ranges Logo
282 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
