Question about Samsung HP-R5072 50 in. Plasma HDTV
High pitch sound after Samsung HDTV warms up- very annoying!! Solution?
  • wegervais Jul 16, 2009
    Contacted Samsung tech support via online chat feature. He had me reset the sound settings to the original default settings. So far so good!
  • 304 Answers
The sound can be coming from the Y-Main bd, X-Main bd, or the Main Power Supply or a combination of those three bds. The Plasma Panel can also cause this. A trained samsung tech will have to trouble shoot the issue. I have found that by replacing the bds one at a time will eventualy eliminate the problem. However you must understand that all plasmas do emit a whining sound that is characteristic of all Plasmas and will not go away completely. If the Plasma is not properly mounted on the wall you can be hearing the amplification of the Normal sound because the sound is bouncing off of the wall.
Posted on Jul 16, 2009
  • Cary Leonardt Jul 16, 2009
I have a Samsung HL-R5677W TV set and now there is no picture at all. Every time you power on the TV the green light flashes and you hear this sound that repeats itself. It sounds like a camera flash, low...
I have a few questions which will determine what your problem may be.
Did or does the set make a high pitched fan like sound or a high pitched whine?
What have you examined so far?
As far as a lamp it is unlikely it will cause such a sound but if you remove it look to see it is intact and not shattered.
Let me know
SD TECH
Sep 23, 2011 | Samsung HL-R5677W 56" HDTV
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture and high pitch sound. I have already replace the bulb
This will give you the general idea, although it's not for your model. They're all generally the same.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 08, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
I have a 47 " samsung tantus 1080i hdtv. It makes a high pitched whistle sound at times which is very annoying(seems to come on when the sound on the tv is also high pitched). I can take the back off and...
You Seam to have already found the problem!, If your Wiggling A Cap or Coil and the sound gos away! its the cause of the problem!, replace it, Or A Quick fix is to Use 100% Silicone around problem cap/coil ~ But Let it Dry! before use (24hr) Geo*
Jul 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
High pitch noise when tv warms up
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Sep 12, 2006 | Philips 55P8241 55" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
371 people viewed this question
Jerry Greenberg
Jerry Greenberg
